[OpenLayers-Users] URL CENTER VAR
chris1211
chris at powerhousetechgrp.com
Sun Apr 27 04:29:26 EDT 2008
I can not get it to work?
chris1211 wrote:
> I am having trouble with geting the url var to center my map here is what
> im using server/map.htm?center=36.33,-88.3&zoom=10
> any help would be greatly appreciated
> here is the code :
> <?xml version="1.0" encoding="UTF-8"?>
> <!DOCTYPE HTML PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
> "DTD/xhtml1-strict.dtd">
> <html xmlns="http://www.w3.org/1999/xhtml">
> <head>
> <title>OpenLayers map preview</title>
> <style type="text/css">
> #map {
> width: 800px;
> height: 400px;
> border: 1px solid black;
> #wrapper {
> width: 800px;
> #location {
> float: right;
> </style>
> <script
> src="http://192.168.11.2:8080/geoserver/openlayers/OpenLayers.js"
> type="text/javascript">
> </script>
> <script defer="defer" type="text/javascript">
> var map;
> var untiled;
> var tiled;
> function setHTML(response) {
> document.getElementById('nodelist').innerHTML =
> response.responseText;
> OpenLayers.IMAGE_RELOAD_ATTEMPTS = 5;
> OpenLayers.DOTS_PER_INCH = 25.4 / 0.28;
> function init(){
> var bounds = new OpenLayers.Bounds(
> 1209252.5526935272, 651041.2129505234,
> 1381167.9232498403, 809964.932844604
> var options = {
> controls: [],
> maxExtent: bounds,
> maxResolution: 671.544416235598,
> projection: "EPSG:2274",
> units: 'm'
> map = new OpenLayers.Map('map', options);
> // setup tiled layer
> tiled = new OpenLayers.Layer.WMS(
> "Geoserver layers - Tiled",
> "http://192.168.11.2:8080/geoserver/wms",
> width: '800',
> layers:
> 'topp:states,topp:county,topp:streets,topp:Buildings,topp:driveway',
> styles: '',
> srs: 'EPSG:2274',
> height: '400',
> format: 'image/png',
> tiled: 'true',
> tilesOrigin : "1209252.5526935272,651041.2129505234"
> {buffer: 0}
> // setup single tiled layer
> untiled = new OpenLayers.Layer.WMS(
> "Geoserver layers - Untiled",
> width: '800',
> layers:
> styles: '',
> srs: 'EPSG:2274',
> height: '400',
> format: 'image/png'
> {singleTile: true, ratio: 1}
> map.addLayers([tiled]);
> // setup controls and initial zooms
> map.addControl(new OpenLayers.Control.PanZoomBar());
> map.addControl(new OpenLayers.Control.Navigation());
> map.addControl(new OpenLayers.Control.Scale($('scale')));
> map.addControl(new OpenLayers.Control.MousePosition({element:
> $('location')}));
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> //map.addControl(new OpenLayers.Control.OverviewMap());
> // support GetFeatureInfo
> map.events.register('click', map, function (e) {
> "Loading... please wait...";
> var url = map.layers[0].getFullRequestString(
> REQUEST: "GetFeatureInfo",
> EXCEPTIONS: "application/vnd.ogc.se_xml",
> BBOX: map.getExtent().toBBOX(),
> X: e.xy.x,
> Y: e.xy.y,
> INFO_FORMAT: 'text/html',
> QUERY_LAYERS: map.layers[0].params.LAYERS,
> FEATURE_COUNT: 50,
> WIDTH: map.size.w,
> HEIGHT: map.size.h
> OpenLayers.loadURL(url, '', this, setHTML, setHTML);
> OpenLayers.Event.stop(e);
> </script>
> </head>
> <body onload="init()">
> <div id="map"></div>
> <div id="wrapper">
> <div id="location"></div>
> <div id="scale"></div>
> </div>
> <div id="nodelist">Click on the map to get feature info</div>
> </body>
> </html>
View this message in context: http://www.nabble.com/URL-CENTER-VAR-tp16860148p16921103.html
