[OpenLayers-Users] delete feature & vertexes
Eric Lemoine eric.c2c at gmail.com
Mon Aug 4 12:27:24 EDT 2008
Hi. Question: How do you distinguish that the user selects a feature
for deletion or modification? I'm trying to understand whether you
need two controls to achieve what you want - using a modify feature
control only might be sufficient and prevent potential problems
because of conflicts between the select feature and modify feature
controls. Cheers. Eric
2008/8/4, Adorian Ardelean <mynature at gmail.com>:
> Hi,
> Thank you for your message. Yes it works, but...
> I have discovered that this problem is in relation with the modify control I
> use within the same application. If I rem line for declaring modify control
> the delete function behaves OK. If I include it, then after delete the
> vertexes remain. If more than one polygon on map then the vertexes disappear
> from previous deleted polygon and appear where the last deleted polygon
> resided.... and so on. On some clicks succession a polygon may be redrawn
> (with lines and fill style), but no delete or drag or edit may be performed.
>   var modifyOptions = {
>                 onModificationStart: function(feature) {
>                     OpenLayers.Console.log("start modifying", feature.id);
>                 onModification: function(feature) {
>                     OpenLayers.Console.log("modified", feature.id);
>                 onModificationEnd: function(feature) {
>                     OpenLayers.Console.log("end modifying", feature.id);
>                 onDelete: function(feature) {
>                    OpenLayers.Console.log("delete", feature.id);
>  controls = {
>                 modify: new OpenLayers.Control.ModifyFeature(vectors,
> modifyOptions),
>                 deletefeature: new OpenLayers.Control.SelectFeature(vectors,
> {onSelect:deleteFeature}),
> function deleteFeature(feature)
>   this.layer.destroyFeatures([feature]);
>   //this.layer.removeFeatures(feature);
> Any hints how to make delete and modify "cooperate"?
> All the best,
> Adorian
> On Mon, Aug 4, 2008 at 2:13 PM, Tim Schaub <tschaub at opengeo.org> wrote:
>> Hey-
>> Adorian Ardelean wrote:
>> > Hi,
>> > After upgrading to OL 2.6, delete feature function does not work
>> correctly:
>> > when a polygon or polyline is removed, the lines that define the
>> > disappear, but the vertexes not (the vertexes appear as the entity is
>> > selected). The code worked flawlessly in previous version. Is something
>> > that I have to be aware and/or modify?
>> > declaration of control
>> > deletefeature: new
>> > OpenLayers.Control.SelectFeature(vectors,{onSelect:deleteFeature})
>> > delete function
>> > function deleteFeature(geometry)
>> >   this.layer.removeFeatures(geometry);
>> > Any hint that may solve this issue is appreciated,
>> I just tried the following and confirmed that the above works.
>> 1) open http://openlayers.org/dev/examples/draw-feature.html
>> 2) draw a polygon (note freehand is true here)
>> 3) in the firebug console, run this code:
>> var del = new OpenLayers.Control.SelectFeature(
>>     map.layers[3], {
>>         onSelect: function(feature) {
>>             map.layers[3].removeFeatures([feature]);
>> map.addControl(del);
>> del.activate();
>> 4) click on your polygon to see it removed
>> I suspect you really want to be calling destroyFeatures instead of
>> removeFeatures - unless you call feature.destroy elsewhere.
>> Tim
>> > Adorian
>> > Dr. Adorian Ardelean
>> > coordinator of myNature Project
>> > proiectul myNature
>> > str. Rascoala din 1907 nr 12
>> > Timisoara 300523
>> > Romania
>> > http://mybiosis.info/nature/portal.php?pagename=firstpage [a Romanian
>> > biodiversity-database]
>> > http://mybiosis.info/nature/portal.php?pagename=adorian [CV]
>> > _______________________________________________
>> > Users mailing list
>> > Users at openlayers.org
>> > http://openlayers.org/mailman/listinfo/users
>> Users mailing list
> proiectul myNature
> Timisoara 300523
> Romania
