[OpenLayers-Users] mapserver does not show oracle layer
FCampos fcampos at efacec.pt
Wed Aug 6 05:41:18 EDT 2008
mapserevr, since it happens the same with shape image.
Sorry, but if anyone can help ... please answer.
Bart van den Eijnden wrote:
> Can you please first determine if this is a Mapserver problem, or an
> OpenLayers problem, and then use the appropriate e-mail list?
> So, check if you MAP file draws with shp2img or not as a first step.
> Best regards,
> Bart
>> Hi,
>> i´m having troubles shwoing a oracle layer in mapserver.
>> in open layers i´ve:
>> map =  new OpenLayers.Map( 'map' ,
>> 		scales: [ 4000000,3000000,2000000,1000000, 500000,200000, 100000,
>> 50000,20000,10000 ],
>> 		maxExtent: new OpenLayers.Bounds(-18,34,4,45),
>> 		numZoomLevels: 10
>> var basemap = new OpenLayers.Layer.WMS.Untiled( "MS 4.10",
>> "http://172.18.210.67:8080/cgi-bin/mapserv.exe?",
>> 	map: '/ms4w/apps/wmssrvrefer/config.map',
>> 	layers: 'border', format: 'png', 'transparent': 'on'},
>> 	{ 	projection:"EPSG:4326" 	} );
>> map.addLayers([basemap]);
>> map.setCenter(new OpenLayers.LonLat(-8, 39.5), 0);
>> In mapfile:
>>   projection
>>     "init=epsg:4326"
>>   end
>>  web
>>      IMAGEPATH "/ms4w/tmp/ms_tmp/"
>>      IMAGEURL "/ms_tmp/"
>>      metadata
>>        wms_title "test"
>>        wms_srs "EPSG:4326"
>>      end
>>   end
>> ## this show the layer !
>>  layer
>>     name major_roads_small_4
>>     group border
>>     type line
>>     projection
>>       "init=epsg:4326"
>>     end
>>     status on
>>     data railways.shp
>>     class
>>       style
>>         color 0 0 0
>>         width 1
>>         antialias true
>>       end
>>     end
>>   end
>> this layer does not show !!
>> layer
>> 	name road_a
>> 	group border
>> 	type line
>> 	projection
>>       		"init=epsg:4326"
>>     	end
>> 	connectiontype oraclespatial
>> 	connection "uui/pwdmydb"
>> 	data "geom_73 from caop_regiao using srid 4326"
>> 	class
>> 	      style
>> 	        color 185 175 155
>> 	        width 3
>> 	        antialias true
>> 	      end
>> 	end
>> end
>> What´s wrong ?
>> View this message in context:
>> http://www.nabble.com/mapserver-does-not-show-oracle-layer-tp18847240p18847240.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://www.nabble.com/mapserver-does-not-show-oracle-layer-tp18847240p18847604.html
