[OpenLayers-Users] TileCache + GetFeatureinfo(Geoserver1.6.4)?
Xiaoyu Guan guanxiaoyu at gmail.com
Wed Aug 6 06:29:54 EDT 2008
Dear All.
the problem have been solved. I simply add another WMS layer to map and hide
it. then GetFeatureinfor can request from that WMS layer. please check the
following codes.
 var map;
        var testlayer;
        var tiled;
        function setHTML(response) {
            document.getElementById('nodelist').innerHTML =
response.responseText;
        OpenLayers.IMAGE_RELOAD_ATTEMPTS = 5;
        OpenLayers.DOTS_PER_INCH = 25.4 / 0.28;
        function init(){
            var bounds = new OpenLayers.Bounds(
                143.83482400000003, -43.648056,
                148.47914100000003, -39.573891
            var options = {
                controls: [],
                maxExtent: bounds,
                maxResolution: 0.018141863281250004,
                projection: "EPSG:4326",
                units: 'degrees'
            map = new OpenLayers.Map('map', options);
            // setup tiled layer
            tiled = new OpenLayers.Layer.WMS(
                "Geoserver layers - Tiled", "
http://127.0.0.1:2010/tilecache/tilecache.py",
                    layers: 'tasmania',
                    styles: '',
                    height: '658',
                    width: '800',
                    srs: 'EPSG:4326',
                    format: 'image/png',
                    tiled: 'true',
                    tilesOrigin : "143.83482400000003,-43.648056"
                {buffer: 0}
            testlayer = new OpenLayers.Layer.WMS(
                "Geoserver layers - Untiled",           "
http://127.0.0.1:2008/geoserver/wms",
                    layers: 'tasmania',
                    styles: '',
                    height: '658',
                    width: '800',
                    srs: 'EPSG:4326',
                    format: 'image/png'
                {singleTile: true, ratio: 1,displayInLayerSwitcher: false /*
Not show this layer */}
            map.addLayers([tiled,testlayer]);
            // setup controls and initial zooms
            map.addControl(new OpenLayers.Control.PanZoomBar());
            map.addControl(new OpenLayers.Control.Navigation());
            map.addControl(new OpenLayers.Control.Scale($('scale')));
            map.addControl(new OpenLayers.Control.MousePosition({element:
$('location')}));
            map.addControl(new OpenLayers.Control.LayerSwitcher());
            //map.addControl(new OpenLayers.Control.OverviewMap());
            map.zoomToExtent(bounds);
            // support GetFeatureInfo
            geoserver=map.layers.slice(1); // copy map.layers to a new
object without TileCache layer
            map.events.register('click', geoserver, function (e) {
                document.getElementById('nodelist').innerHTML = "Loading...
please wait...";
                var url =  geoserver[0].getFullRequestString(
                        REQUEST: "GetFeatureInfo",
                        EXCEPTIONS: "application/vnd.ogc.se_xml",
                        BBOX: geoserver[0].getExtent().toBBOX(),
                        X: e.xy.x,
                        Y: e.xy.y,
                        INFO_FORMAT: 'text/html',
                        QUERY_LAYERS: geoserver[0].params.LAYERS,
                        FEATURE_COUNT: 50,
                        WIDTH: map.size.w,
                        HEIGHT: map.size.h
                    "http://127.0.0.1:2008/geoserver/wms"
                OpenLayers.loadURL(url, '', this, setHTML, setHTML);
                OpenLayers.Event.stop(e);
All the best
Xiaoyu
On Thu, Jul 31, 2008 at 2:04 PM, Xiaoyu Guan <guanxiaoyu at gmail.com> wrote:
> Dear All:
> I have a problem on building getFeatureinfo. I have use Geoserver 1.6.4,
> and Tilecache. I pointed my geoserver sample page to my tilecache. then I
> still want getfeatureinfo function of Geoserver. I try to modified it, but
> not success.
>         var map;
>         var testlayer;
>         var tiled;
>             document.getElementById('nodelist').innerHTML = response.responseText;
>         function init(){
>             var options = {
>                 controls: [],
>                 maxExtent: bounds,
>                 units: 'degrees'
>                 "Geoserver layers - Tiled", "http://127.0.0.1:2010/tilecache/tilecache.py",
>                     layers: 'tasmania',
>                     styles: '',
>                     height: '658',
>                     width: '800',
>                     srs: 'EPSG:4326',
>                     tiled: 'true',
>                 {buffer: 0}
>             map.addLayer( tiled);
>             map.addControl(new OpenLayers.Control.MousePosition({element: $('location')}));
>                 "Geoserver layers - Untiled", "http://127.0.0.1:2008/geoserver/wms",
>                     layers: 'tasmania',
>                     styles: '',
>                     height: '658',
>                     width: '800',
>                     srs: 'EPSG:4326',
>                     format: 'image/png'
>                 {singleTile: true, ratio: 1}
> // here I would like to add stuff like this
> //then geoserver only contain one layer, which is testlayer
>              var geoserver = map;
>                  geoserver.addLayer(testlayer);
>             geoserver.events.register('click', geoserver, function (e) {
>                 document.getElementById('nodelist').innerHTML = "Loading... please wait...";
>                 var url =  geoserver.layers[0].getFullRequestString(
>                         BBOX: geoserver.getExtent().toBBOX(),
>                         X: e.xy.x,
>                         Y: e.xy.y,
>                         QUERY_LAYERS: geoserver.layers[0].params.LAYERS,
>                         FEATURE_COUNT: 50,
>                         WIDTH: geoserver.size.w,
>                         HEIGHT: geoserver.size.h
> b
> because I am not a JavaScript expert. it is hard for me to replace the
> layer, such as map.layers[0]. how can use tilecache as base layer, and have
> getFeatureInfo on top of it at same time?
> Much much thanks
> all the best
> Xiaoyu
> PS, I have already send a copy to Geoserver mailling list
> Xiaoyu Guan (Sam)
> Geo-information Science
> Wageningen UR
Xiaoyu Guan (Sam)
Wageningen UR
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080806/9dbd5b9d/attachment.html
