[OpenLayers-Users] Custom box activation
Simo D simone.dalmasso at gmail.com
Thu Aug 7 06:14:28 EDT 2008
Hi all, I've create a select menu in which one option is to draw a rectangle
that return his bounds coordinates. The select has an onchange listener that
removes the pan and zoom controls and activate the rectangle selecion. I'
used the code in the examples but without the keyMask:
		var control  = new OpenLayers.Control();
    OpenLayers.Util.extend(control, {
        draw: function () {
            // this Handler.Box will intercept the shift-mousedown
            // before Control.MouseDefault gets to see it
            this.box = new OpenLayers.Handler.Box(control,
                {"done": this.notice});
            this.box.activate();
        notice: function (bounds) {
            var ll = map.getLonLatFromPixel(new
OpenLayers.Pixel(bounds.left, bounds.bottom));
            var ur = map.getLonLatFromPixel(new
OpenLayers.Pixel(bounds.right, bounds.top));
            $('info').update(ll.lon.toFixed(4) + ", " +
                  ll.lat.toFixed(4) + ", " +
                  ur.lon.toFixed(4) + ", " +
                  ur.lat.toFixed(4));
									this.box.deactivate();
		map.addControl(control);
It works but it requires a click on the map to be activated. Is it possible
to activate it immediately when I select the option in the menu?
Thanks
Simone
View this message in context: http://www.nabble.com/Custom-box-activation-tp18867498p18867498.html
