[OpenLayers-Users] Re moved markers still occupy memory :/
Christopher Schmidt crschmidt at metacarta.com
Fri Aug 8 10:32:15 EDT 2008
On Fri, Aug 08, 2008 at 02:36:19AM -0700, realjax wrote:
> Try destroying them as well on the markers layer
> If you just want to get rid of all markers on the marker layer it should be:
> localizationLayer.destroy()
> (assuming localizationLayer is of type  OpenLayers.Layer.markers )
> The problem might be in the fact that the removeMarker makes use of
> OpenLayers.Util.RemoveItem, which in turn removes elements from an array
> using the array.splice method. And IE 6 doesn't support this..
Er, I think this is a very unlikely statement... removeItem is used
extensively throughout the code, and if it didn't work in IE6, we'd have
a lot of trouble.
I've just confirmed via Firebug Lite in IE that
OpenLayers.Util.removeItem(['1','2','3'], '2')
returns:
['1', '3']
So, I don't think looking at OpenLayers.Util.removeItem askance is
likely to work well.
Regards,
Christopher Schmidt
MetaCarta
