[OpenLayers-Users] Loading WMC layers at overlays?
Arnd Wippermann arnd.wippermann at web.de
Sat Aug 9 17:29:19 EDT 2008
Why not loop over context.layers before adding the layers?
Arnd Wippermann
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Bart van den Eijnden (OSGIS)
Gesendet: Samstag, 9. August 2008 12:04
An: jvanulde
Cc: users at openlayers.org
Betreff: Re: [OpenLayers-Users] Loading WMC layers at overlays?
Hi Joost,
unfortunately there is no easy way to override this at the moment in OL, see
also:
http://trac.openlayers.org/ticket/1513
What you can do is loop over your layers and then set
layer.params.TRANSPARENT to 'true', but it might be too late since the layer
will have actually been drawn already.
Otherwise change the default WMS parameters of OpenLayers,
     * Constant: DEFAULT_PARAMS
     * {Object} Hashtable of default parameter key/value pairs
    DEFAULT_PARAMS: { service: "WMS",
                      version: "1.1.1",
                      request: "GetMap",
                      styles: "",
                      exceptions: "application/vnd.ogc.se_inimage",
                      format: "image/jpeg"
to e.g. format "image/png" and transparent "true".
Best regards,
Bart
jvanulde wrote:
> Hi Bart,  thanks for that as I think I am half way there now.  The
> only issue now is that the layers are not transparent.  They are
> coming from Mapserver as PNG's.  Here is my code:
>         OpenLayers.IMAGE_RELOAD_ATTEMPTS = 2;
>         OpenLayers.Util.onImageLoadErrorColor = "transparent";
>         var layerOptions = {
>             isBaseLayer: false,
>             singleTile: true,
>             buffer: 0,
>             ratio: 1
>         var format = new OpenLayers.Format.WMC({'layerOptions':
> layerOptions});
>         var map, context;
>         function initMap()
>             // parse wmc into context object
>             var wmc = document.getElementById('<%= hidWMC.ClientID
> %>').value;
>             context = format.read(wmc, {map: map});
>             // construct a map given the context
>             var mapOptions = {
>                 maxExtent: context.bounds,
>                 projection: context.srs
>             map = new OpenLayers.Map("map", mapOptions);
>             var baseLayerOptions = {
>                 isBaseLayer: true,
>                 displayInLayerSwitcher: false
>             var fake = new OpenLayers.Layer('fake', baseLayerOptions);
>             map.addLayer(fake);
>             map.addLayers(context.layers);
>             map.addControl(new OpenLayers.Control.LayerSwitcher());
>             map.zoomToMaxExtent();
> Is there a way to make the layers transparent now that I have loaded them?
> I think the problem is elsewhere but need some pointers on where to
> look.  I have loaded the context in another viewer and the layers come
> in as expected.
> Bart van den Eijnden wrote:
>> Hi Joost,
>> you can pass layerOptions to the Format.WMC constructor in order to
>> do this. Code example:
>> mapfish.OGCUtil.readWMC = function(map, response, noZoom) {
>>     var format = new OpenLayers.Format.WMC({layerOptions: {isBaseLayer:
>> false, singleTile: true, buffer: 0,ratio: 1}});
>>     // remove all layers except the baselayer
>>     for (var i = map.layers.length-1; i >= 0; i--) {
>>         if (!map.layers[i].isBaseLayer) {
>>             map.removeLayer(map.layers[i], false);
>>     map = format.read(response.responseText, {map: map});
>> Best regards,
>> Bart
>>> Thanks John, that works.  Now I need to know how to convert all of
>>> the layers in my WMC to overlay's.  Any ideas?
>>> -----Original Message-----
>>> From: John Pulles [mailto:john.pulles at gmail.com]
>>> Sent: Wed 06/08/2008 2:49 PM
>>> To: Van Ulden, Joost
>>> Subject: Re: [OpenLayers-Users] Loading WMC layers at overlays?
>>> 2008/8/6 jvanulde <jvanulde at nrcan.gc.ca>
>>>> Is this possible?  I want to add a fake base layer and load all the
>>>> WMC layers as overlays.  Any ideas on how one would go about doing
this?
>>> You can add a fake base layer with
>>> map.addLayer(new OpenLayers.Layer('None', {isBaseLayer: true}));
>>> Regards,
>>> John
>>>> View this message in context:
>>>> http://www.nabble.com/Loading-WMC-layers-at-overlays--tp18859376p18
>>>> 859376.html Sent from the OpenLayers Users mailing list archive at
>>>> Nabble.com.
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>>> Users mailing list
>> Users mailing list
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
Users mailing list
