[OpenLayers-Users] Loading WMC layers at overlays?
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Sun Aug 10 10:49:37 EDT 2008
Hi Arnd,
you're absolute right. I didn't see that Joost was not merging the
context with an existing map object, like I am doing, in which case you
don't have that kind of control.
Best regards,
Bart
Arnd Wippermann wrote:
> Why not loop over context.layers before adding the layers?
> Arnd Wippermann
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von Bart van den Eijnden (OSGIS)
> Gesendet: Samstag, 9. August 2008 12:04
> An: jvanulde
> Cc: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] Loading WMC layers at overlays?
> Hi Joost,
> unfortunately there is no easy way to override this at the moment in OL, see
> also:
> http://trac.openlayers.org/ticket/1513
> What you can do is loop over your layers and then set
> layer.params.TRANSPARENT to 'true', but it might be too late since the layer
> will have actually been drawn already.
> Otherwise change the default WMS parameters of OpenLayers,
>      * Constant: DEFAULT_PARAMS
>      * {Object} Hashtable of default parameter key/value pairs
>     DEFAULT_PARAMS: { service: "WMS",
>                       version: "1.1.1",
>                       request: "GetMap",
>                       styles: "",
>                       exceptions: "application/vnd.ogc.se_inimage",
>                       format: "image/jpeg"
> to e.g. format "image/png" and transparent "true".
> Best regards,
> Bart
> jvanulde wrote:
>> Hi Bart,  thanks for that as I think I am half way there now.  The
>> only issue now is that the layers are not transparent.  They are
>> coming from Mapserver as PNG's.  Here is my code:
>>         OpenLayers.IMAGE_RELOAD_ATTEMPTS = 2;
>>         OpenLayers.Util.onImageLoadErrorColor = "transparent";
>>         var layerOptions = {
>>             isBaseLayer: false,
>>             singleTile: true,
>>             buffer: 0,
>>             ratio: 1
>>         var format = new OpenLayers.Format.WMC({'layerOptions':
>> layerOptions});
>>         var map, context;
>>         function initMap()
>>             // parse wmc into context object
>>             var wmc = document.getElementById('<%= hidWMC.ClientID
>> %>').value;
>>             context = format.read(wmc, {map: map});
>>             // construct a map given the context
>>             var mapOptions = {
>>                 maxExtent: context.bounds,
>>                 projection: context.srs
>>             map = new OpenLayers.Map("map", mapOptions);
>>             var baseLayerOptions = {
>>                 isBaseLayer: true,
>>                 displayInLayerSwitcher: false
>>             var fake = new OpenLayers.Layer('fake', baseLayerOptions);
>>             map.addLayer(fake);
>>             map.addLayers(context.layers);
>>             map.addControl(new OpenLayers.Control.LayerSwitcher());
>>             map.zoomToMaxExtent();
>> Is there a way to make the layers transparent now that I have loaded them?
>> I think the problem is elsewhere but need some pointers on where to
>> look.  I have loaded the context in another viewer and the layers come
>> in as expected.
>> Bart van den Eijnden wrote:
>>> Hi Joost,
>>> you can pass layerOptions to the Format.WMC constructor in order to
>>> do this. Code example:
>>> mapfish.OGCUtil.readWMC = function(map, response, noZoom) {
>>>     var format = new OpenLayers.Format.WMC({layerOptions: {isBaseLayer:
>>> false, singleTile: true, buffer: 0,ratio: 1}});
>>>     // remove all layers except the baselayer
>>>     for (var i = map.layers.length-1; i >= 0; i--) {
>>>         if (!map.layers[i].isBaseLayer) {
>>>             map.removeLayer(map.layers[i], false);
>>>     map = format.read(response.responseText, {map: map});
>>> Best regards,
>>> Bart
>>>> Thanks John, that works.  Now I need to know how to convert all of
>>>> the layers in my WMC to overlay's.  Any ideas?
>>>> -----Original Message-----
>>>> From: John Pulles [mailto:john.pulles at gmail.com]
>>>> Sent: Wed 06/08/2008 2:49 PM
>>>> To: Van Ulden, Joost
>>>> Subject: Re: [OpenLayers-Users] Loading WMC layers at overlays?
>>>> 2008/8/6 jvanulde <jvanulde at nrcan.gc.ca>
>>>>> Is this possible?  I want to add a fake base layer and load all the
>>>>> WMC layers as overlays.  Any ideas on how one would go about doing
> this?
>>>> You can add a fake base layer with
>>>> map.addLayer(new OpenLayers.Layer('None', {isBaseLayer: true}));
>>>> Regards,
>>>> John
>>>>> View this message in context:
>>>>> http://www.nabble.com/Loading-WMC-layers-at-overlays--tp18859376p18
>>>>> 859376.html Sent from the OpenLayers Users mailing list archive at
>>>>> Nabble.com.
>>>>> _______________________________________________
>>>>> Users mailing list
>>>>> Users at openlayers.org
>>>>> http://openlayers.org/mailman/listinfo/users
>>>> Users mailing list
>>> Users mailing list
> OSGIS, Open Source GIS
> bartvde at osgis.nl
> http://www.osgis.nl
> Users mailing list
bartvde at osgis.nl
http://www.osgis.nl
