[OpenLayers-Users] Loading WMC layers at overlays?
jvanulde jvanulde at NRCAN.GC.CA
Mon Aug 11 03:08:15 EDT 2008
I didn't realize that I could merge with an existing map object.  How would
one do that?  Arnd, I did try to loop over the layers in the context before
I added them to my map oject but I can't seem to access any of the
properties.  How do I access the transparent property/parameter?
Thanks for helping me out with this.
Bart van den Eijnden wrote:
> Hi Arnd,
> you're absolute right. I didn't see that Joost was not merging the
> context with an existing map object, like I am doing, in which case you
> don't have that kind of control.
> Best regards,
> Bart
> Arnd Wippermann wrote:
>> Why not loop over context.layers before adding the layers?
>> Arnd Wippermann
>> -----Ursprüngliche Nachricht-----
>> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
>> Im
>> Auftrag von Bart van den Eijnden (OSGIS)
>> Gesendet: Samstag, 9. August 2008 12:04
>> An: jvanulde
>> Cc: users at openlayers.org
>> Betreff: Re: [OpenLayers-Users] Loading WMC layers at overlays?
>> Hi Joost,
>> unfortunately there is no easy way to override this at the moment in OL,
>> see
>> also:
>> http://trac.openlayers.org/ticket/1513
>> What you can do is loop over your layers and then set
>> layer.params.TRANSPARENT to 'true', but it might be too late since the
>> layer
>> will have actually been drawn already.
>> Otherwise change the default WMS parameters of OpenLayers,
>>      * Constant: DEFAULT_PARAMS
>>      * {Object} Hashtable of default parameter key/value pairs
>>     DEFAULT_PARAMS: { service: "WMS",
>>                       version: "1.1.1",
>>                       request: "GetMap",
>>                       styles: "",
>>                       exceptions: "application/vnd.ogc.se_inimage",
>>                       format: "image/jpeg"
>> to e.g. format "image/png" and transparent "true".
>> Best regards,
>> Bart
>> jvanulde wrote:
>>> Hi Bart,  thanks for that as I think I am half way there now.  The
>>> only issue now is that the layers are not transparent.  They are
>>> coming from Mapserver as PNG's.  Here is my code:
>>>         OpenLayers.IMAGE_RELOAD_ATTEMPTS = 2;
>>>         OpenLayers.Util.onImageLoadErrorColor = "transparent";
>>>         var layerOptions = {
>>>             isBaseLayer: false,
>>>             singleTile: true,
>>>             buffer: 0,
>>>             ratio: 1
>>>         var format = new OpenLayers.Format.WMC({'layerOptions':
>>> layerOptions});
>>>         var map, context;
>>>         function initMap()
>>>             // parse wmc into context object
>>>             var wmc = document.getElementById('<%= hidWMC.ClientID
>>> %>').value;
>>>             context = format.read(wmc, {map: map});
>>>             // construct a map given the context
>>>             var mapOptions = {
>>>                 maxExtent: context.bounds,
>>>                 projection: context.srs
>>>             map = new OpenLayers.Map("map", mapOptions);
>>>             var baseLayerOptions = {
>>>                 isBaseLayer: true,
>>>                 displayInLayerSwitcher: false
>>>             var fake = new OpenLayers.Layer('fake', baseLayerOptions);
>>>             map.addLayer(fake);
>>>             map.addLayers(context.layers);
>>>             map.addControl(new OpenLayers.Control.LayerSwitcher());
>>>             map.zoomToMaxExtent();
>>> Is there a way to make the layers transparent now that I have loaded
>>> them?
>>> I think the problem is elsewhere but need some pointers on where to
>>> look.  I have loaded the context in another viewer and the layers come
>>> in as expected.
>>>> Hi Joost,
>>>> you can pass layerOptions to the Format.WMC constructor in order to
>>>> do this. Code example:
>>>> mapfish.OGCUtil.readWMC = function(map, response, noZoom) {
>>>>     var format = new OpenLayers.Format.WMC({layerOptions: {isBaseLayer:
>>>> false, singleTile: true, buffer: 0,ratio: 1}});
>>>>     // remove all layers except the baselayer
>>>>     for (var i = map.layers.length-1; i >= 0; i--) {
>>>>         if (!map.layers[i].isBaseLayer) {
>>>>             map.removeLayer(map.layers[i], false);
>>>>     map = format.read(response.responseText, {map: map});
>>>> Best regards,
>>>> Bart
>>>>> Thanks John, that works.  Now I need to know how to convert all of
>>>>> the layers in my WMC to overlay's.  Any ideas?
>>>>> -----Original Message-----
>>>>> From: John Pulles [mailto:john.pulles at gmail.com]
>>>>> Sent: Wed 06/08/2008 2:49 PM
>>>>> To: Van Ulden, Joost
>>>>> Subject: Re: [OpenLayers-Users] Loading WMC layers at overlays?
>>>>> 2008/8/6 jvanulde <jvanulde at nrcan.gc.ca>
>>>>>> Is this possible?  I want to add a fake base layer and load all the
>>>>>> WMC layers as overlays.  Any ideas on how one would go about doing
>> this?
>>>>> You can add a fake base layer with
>>>>> map.addLayer(new OpenLayers.Layer('None', {isBaseLayer: true}));
>>>>> Regards,
>>>>> John
>>>>>> View this message in context:
>>>>>> http://www.nabble.com/Loading-WMC-layers-at-overlays--tp18859376p18
>>>>>> 859376.html Sent from the OpenLayers Users mailing list archive at
>>>>>> Nabble.com.
>>>>>> _______________________________________________
>>>>>> Users mailing list
>>>>>> Users at openlayers.org
>>>>>> http://openlayers.org/mailman/listinfo/users
>>>>> Users mailing list
>>>> Users mailing list
>> OSGIS, Open Source GIS
>> bartvde at osgis.nl
>> http://www.osgis.nl
>> Users mailing list
> bartvde at osgis.nl
> http://www.osgis.nl
> Users mailing list
View this message in context: http://www.nabble.com/Loading-WMC-layers-at-overlays--tp18859376p18921083.html
