[OpenLayers-Users] Loading WMC layers at overlays?
bartvde at osgis.nl bartvde at osgis.nl
Mon Aug 11 03:13:22 EDT 2008
Hi Joost,
first question:
for (var i=0; i<context.layers.length;i++) {
  var layer = context.layers[i];
  layer.params.TRANSPARENT = 'TRUE';
Second question:
You can pass in an existing map object like:
map = format.read(response.responseText, {map: map});
Best regards,
Bart
> I didn't realize that I could merge with an existing map object.  How
> would
> one do that?  Arnd, I did try to loop over the layers in the context
> before
> I added them to my map oject but I can't seem to access any of the
> properties.  How do I access the transparent property/parameter?
> Thanks for helping me out with this.
> Bart van den Eijnden wrote:
>> Hi Arnd,
>> you're absolute right. I didn't see that Joost was not merging the
>> context with an existing map object, like I am doing, in which case you
>> don't have that kind of control.
>> Best regards,
>> Bart
>> Arnd Wippermann wrote:
>>> Why not loop over context.layers before adding the layers?
>>> Arnd Wippermann
>>> -----Ursprüngliche Nachricht-----
>>> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
>>> Im
>>> Auftrag von Bart van den Eijnden (OSGIS)
>>> Gesendet: Samstag, 9. August 2008 12:04
>>> An: jvanulde
>>> Cc: users at openlayers.org
>>> Betreff: Re: [OpenLayers-Users] Loading WMC layers at overlays?
>>> Hi Joost,
>>> unfortunately there is no easy way to override this at the moment in
>>> OL,
>>> see
>>> also:
>>> http://trac.openlayers.org/ticket/1513
>>> What you can do is loop over your layers and then set
>>> layer.params.TRANSPARENT to 'true', but it might be too late since the
>>> layer
>>> will have actually been drawn already.
>>> Otherwise change the default WMS parameters of OpenLayers,
>>>      * Constant: DEFAULT_PARAMS
>>>      * {Object} Hashtable of default parameter key/value pairs
>>>     DEFAULT_PARAMS: { service: "WMS",
>>>                       version: "1.1.1",
>>>                       request: "GetMap",
>>>                       styles: "",
>>>                       exceptions: "application/vnd.ogc.se_inimage",
>>>                       format: "image/jpeg"
>>> to e.g. format "image/png" and transparent "true".
>>> Best regards,
>>> Bart
>>> jvanulde wrote:
>>>> Hi Bart,  thanks for that as I think I am half way there now.  The
>>>> only issue now is that the layers are not transparent.  They are
>>>> coming from Mapserver as PNG's.  Here is my code:
>>>>         OpenLayers.IMAGE_RELOAD_ATTEMPTS = 2;
>>>>         OpenLayers.Util.onImageLoadErrorColor = "transparent";
>>>>         var layerOptions = {
>>>>             isBaseLayer: false,
>>>>             singleTile: true,
>>>>             buffer: 0,
>>>>             ratio: 1
>>>>         var format = new OpenLayers.Format.WMC({'layerOptions':
>>>> layerOptions});
>>>>         var map, context;
>>>>         function initMap()
>>>>             // parse wmc into context object
>>>>             var wmc = document.getElementById('<%= hidWMC.ClientID
>>>> %>').value;
>>>>             context = format.read(wmc, {map: map});
>>>>             // construct a map given the context
>>>>             var mapOptions = {
>>>>                 maxExtent: context.bounds,
>>>>                 projection: context.srs
>>>>             map = new OpenLayers.Map("map", mapOptions);
>>>>             var baseLayerOptions = {
>>>>                 isBaseLayer: true,
>>>>                 displayInLayerSwitcher: false
>>>>             var fake = new OpenLayers.Layer('fake', baseLayerOptions);
>>>>             map.addLayer(fake);
>>>>             map.addLayers(context.layers);
>>>>             map.addControl(new OpenLayers.Control.LayerSwitcher());
>>>>             map.zoomToMaxExtent();
>>>> Is there a way to make the layers transparent now that I have loaded
>>>> them?
>>>> I think the problem is elsewhere but need some pointers on where to
>>>> look.  I have loaded the context in another viewer and the layers come
>>>> in as expected.
>>>>> Hi Joost,
>>>>> you can pass layerOptions to the Format.WMC constructor in order to
>>>>> do this. Code example:
>>>>> mapfish.OGCUtil.readWMC = function(map, response, noZoom) {
>>>>>     var format = new OpenLayers.Format.WMC({layerOptions:
>>>>> {isBaseLayer:
>>>>> false, singleTile: true, buffer: 0,ratio: 1}});
>>>>>     // remove all layers except the baselayer
>>>>>     for (var i = map.layers.length-1; i >= 0; i--) {
>>>>>         if (!map.layers[i].isBaseLayer) {
>>>>>             map.removeLayer(map.layers[i], false);
>>>>> Best regards,
>>>>> Bart
>>>>>> Thanks John, that works.  Now I need to know how to convert all of
>>>>>> the layers in my WMC to overlay's.  Any ideas?
>>>>>> -----Original Message-----
>>>>>> From: John Pulles [mailto:john.pulles at gmail.com]
>>>>>> Sent: Wed 06/08/2008 2:49 PM
>>>>>> To: Van Ulden, Joost
>>>>>> Subject: Re: [OpenLayers-Users] Loading WMC layers at overlays?
>>>>>> 2008/8/6 jvanulde <jvanulde at nrcan.gc.ca>
>>>>>>> Is this possible?  I want to add a fake base layer and load all the
>>>>>>> WMC layers as overlays.  Any ideas on how one would go about doing
>>> this?
>>>>>> You can add a fake base layer with
>>>>>> map.addLayer(new OpenLayers.Layer('None', {isBaseLayer: true}));
>>>>>> Regards,
>>>>>> John
>>>>>>> View this message in context:
>>>>>>> http://www.nabble.com/Loading-WMC-layers-at-overlays--tp18859376p18
>>>>>>> 859376.html Sent from the OpenLayers Users mailing list archive at
>>>>>>> Nabble.com.
>>>>>>> _______________________________________________
>>>>>>> Users mailing list
>>>>>>> Users at openlayers.org
>>>>>>> http://openlayers.org/mailman/listinfo/users
>>>>>> Users mailing list
>>>>> Users mailing list
>>> OSGIS, Open Source GIS
>>> bartvde at osgis.nl
>>> http://www.osgis.nl
>>> Users mailing list
>> bartvde at osgis.nl
>> http://www.osgis.nl
>> Users mailing list
> http://www.nabble.com/Loading-WMC-layers-at-overlays--tp18859376p18921083.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
