[OpenLayers-Users] Loading WMC layers at overlays?
jvanulde jvanulde at NRCAN.GC.CA
Wed Aug 13 20:08:46 EDT 2008
Thanks Bart that worked.  Below is the code in case someone else can use it:
        OpenLayers.IMAGE_RELOAD_ATTEMPTS = 2;
        OpenLayers.Util.onImageLoadErrorColor = "transparent";
        var layerOptions = {
            isBaseLayer: false,
            singleTile: true,
            buffer: 0,
            ratio: 1
        var format = new OpenLayers.Format.WMC({'layerOptions':
layerOptions});
        var map, context;
        function initMap()
            // parse wmc into context object
            var wmc =
document.getElementById('hiddenWMCContentsField').value;
            context = format.read(wmc, {map: map});
            for (var i=0; i<context.layers.length;i++)
              var layer = context.layers[i];
              layer.params.TRANSPARENT = 'TRUE';
            // construct a map given the context
            var mapOptions = {
                maxExtent: context.bounds,
                projection: context.srs
            map = new OpenLayers.Map("map", mapOptions);
            // create a fake base layer
            var baseLayerOptions = {
                isBaseLayer: true,
                displayInLayerSwitcher: false
            var fake = new OpenLayers.Layer('fake', baseLayerOptions);
            map.addLayer(fake);
            // add the context layers to the map
            map.addLayers(context.layers);
            map.addControl(new OpenLayers.Control.LayerSwitcher());
            map.zoomToMaxExtent();
View this message in context: http://www.nabble.com/Loading-WMC-layers-at-overlays--tp18859376p18973615.html
