[OpenLayers-Users] Map Layer Requirements
Eric Lemoine eric.c2c at gmail.com
Wed Aug 13 15:56:08 EDT 2008
Hi Bill. You need your vector layer be a base layer. By default vector
layers aren't base layers so you need an explicit option for this at
creation time: new OpenLayers.Layer.Vector("vector", {isBaseLayer:
false}). Hope i am correct and this is helping :-) Eric
2008/8/13, Bill Thoen <bthoen at gisnet.com>:
> I'm trying to set up some little experimental maps in OpenLayers using
> just a vector layer -- no base map. It's not working and I wondered is a
> base map layer required, or can you supply all the necessary options
> when you create the map object?
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
