[OpenLayers-Users] Map Layer Requirements
Bill Thoen bthoen at gisnet.com
Wed Aug 13 15:46:05 EDT 2008
I'm trying to set up some little experimental maps in OpenLayers using
just a vector layer -- no base map. It's not working and I wondered is a
base map layer required, or can you supply all the necessary options
when you create the map object?
