[OpenLayers-Users] a error while using the proxy.cgi under Windows.
bartvde at osgis.nl bartvde at osgis.nl
Thu Aug 14 05:10:55 EDT 2008
Do you have Python installed?
Is the path to the Python interpreter correct in the top section of
proxy.cgi?
Best regards,
Bart
>  Hi, First I apologyze for sending several similar topic. Because I didn't
> receive  the message I sent before so I couldn't reply to it, but I have
> come across a new problem so I had to launch a new topic.
> I use the proxy under Tomcat5.5 in Windos OS, When I access the proxy.cgi:
> http://localhost:8080/geoserver/cgi-bin/proxy.cgi, I it print:
>  Some unexpected error occurred. Error text was: <urlopen error (10106,
> 'getaddrinfo failed')>
> I use the can access the http://www.openlayers.org/ through
> browser(IE7.0).
> I tried other sites with
> http://localhost:8080/geoserver/cgi-bin/proxy.cgi?url=http://www.openstreetmap.org
> .  I got the HTTP 500 internal error. Any suggestions.
>  _______________________________________________
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
