[OpenLayers-Users] Loading Panel not always going away
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Thu Aug 14 15:48:32 EDT 2008
Hi Linda,
are you using 2.6?
The following should have made sure this works correctly:
http://trac.openlayers.org/ticket/842
Best regards,
Bart
Linda_Rawson wrote:
> I am again facing issues with the loading panel not going away.  It seems
> when the tiles in question are an error, 404 not found or something like
> that, the count is not getting decremented so that the loadend event fires.
> Where did you call this from?
> realjax wrote:
>> map.layers[0].events.triggerEvent("loadend");
> Thanks,
> Linda Rawson
> realjax wrote:
>> Linda_Rawson wrote:
>>> Sometimes it does not go away after all layers are loaded.  What can I
>>> do?
>> The loading control is a cool one. ( thanks Bart!).
>> I had some issues as well with events not being fired on some layers
>> (layer.Markers for instance).
>> So I did it manually:
>> Works like a charm :-)
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
