[OpenLayers-Users] Loading Panel not always going away
Linda Rawson linda.rawson at gmail.com
Thu Aug 14 15:59:57 EDT 2008
I am using 2.6 and I have verified that this code is in image.js.
Linda
On Thu, Aug 14, 2008 at 1:48 PM, Bart van den Eijnden (OSGIS) <
bartvde at osgis.nl> wrote:
> Hi Linda,
> are you using 2.6?
> The following should have made sure this works correctly:
> http://trac.openlayers.org/ticket/842
> Best regards,
> Bart
> Linda_Rawson wrote:
>> I am again facing issues with the loading panel not going away.  It seems
>> when the tiles in question are an error, 404 not found or something like
>> that, the count is not getting decremented so that the loadend event
>> fires.
>> Where did you call this from?
>> realjax wrote:
>>> map.layers[0].events.triggerEvent("loadend");
>> Thanks,
>> Linda Rawson
>> realjax wrote:
>>> Linda_Rawson wrote:
>>>> Sometimes it does not go away after all layers are loaded.  What can I
>>>> do?
>>> The loading control is a cool one. ( thanks Bart!).
>>> I had some issues as well with events not being fired on some layers
>>> (layer.Markers for instance).
>>> So I did it manually:
>>> Works like a charm :-)
> OSGIS, Open Source GIS
> bartvde at osgis.nl
> http://www.osgis.nl
Linda Rawson
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080814/b42ebb8c/attachment.html
