[OpenLayers-Users] CQL queries with WFS
Arnd Wippermann arnd.wippermann at web.de
Thu Aug 14 15:50:40 EDT 2008
Does MapServer support CQL? If so I would be interested. Can someone point
me to a source, how to use it? Internet search shows nothing for MapServer.
Arnd Wippermann
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Brenningmeyer, Todd
Gesendet: Donnerstag, 14. August 2008 17:19
An: bartvde at osgis.nl
Cc: Openlayers Users List
Betreff: Re: [OpenLayers-Users] CQL queries with WFS
I used the code below but the map still returned all of the villages.  It
seems very strange that both my CQL_Filter and URL style filters aren't
working.  I'm sure I'm missing something but the filter process just doesn't
seem to like my queries (at least in terms of the syntax I'm using).  The
CQL_Filter params did appear in the params section within firebug when I ran
it but in a vertical format with each letter listed after a number...so 0 C
1 Q 2 L and so on in a vertical column.  I'm not sure if this makes sense or
if it is important to the filter problem.  Thanks again for your help.  If
you have any other suggestions about using the CQL_FILTER or a URL style
filter please let me know.  I've been tinkering with this for quite a while
without success so your help is very much appreciated.
Thanks again,
Todd
var wfsLayer = new OpenLayers.Layer.WFS( "villages",
"http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&typen
ame=villages&request=getfeature&version=1.0.0&service=wfs&",
    styleMap: oStyleMap
var value = "nomos='Eleia'";
wfsLayer.mergeNewParams('CQL_FILTER:' + escape(value));  (I've used both :
and = after CQL_FILTER but neither seemed to work)
From: bartvde at osgis.nl [mailto:bartvde at osgis.nl]
Sent: Thu 8/14/2008 9:23 AM
To: Brenningmeyer, Todd
Cc: bartvde at osgis.nl; Andreas Hocevar; Eric Lemoine; Openlayers Users List
Subject: RE: [OpenLayers-Users] CQL queries with WFS
Can you try something like:
http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&typena
me=villages&request=getfeature&version=1.0.0&service=wfs&,{
    styleMap: oStyleMap
wfsLayer.mergeNewParams({'CQL_FILTER', escape(value)});
Best regards,
Bart
> Bart,
> I tried escaping the quotes around the value of the nomos but
> unfortunately it didn't change the returned results.  I used
> backslashes in front of the single quotes around Eleia.  Is this what you
had in mind?
>  It may be that I'm not escaping the right part of the filter.
> Thanks,
> Todd
http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&CQL_FI
LTER=nomos=\'Eleia\'&typename=villages&request=getfeature&version=1.0.0&serv
ice=wfs,{
>                 styleMap: oStyleMap
> Sent: Thu 8/14/2008 8:52 AM
> Cc: Andreas Hocevar; Eric Lemoine; Openlayers Users List
> Subject: Re: [OpenLayers-Users] CQL queries with WFS
> Have you tried escaping the value of your parameter CQL_FILTER?
> Best regards,
> Bart
>> Thanks Andreas and Eric.  I've tried a few different options with the
>> filter but without success.  I'm using the following filter and have
>> tried this with the map location moved into the params section and a
>> few other times with everything in a single URL request but still no
>> luck.  The request returns all of the villages with none of these
>> filtered out.  If you have any ideas that might help please let me
>> know.  Thanks again for your help.
>> Todd
"http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&CQL_F
ILTER=nomos='Eleia'
>> <http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.ma
>> p&CQL_FILTER=nomos='Eleia',{//
>> p&CQL_FILTER=nomos='Eleia',{//<Filter> >
>> ><PropertyIsEqualTo><PropertyName>nom_nr</PropertyName><Literal>39</L
>> >iteral></PropertyIsEqualTo></Filter>
>>                service: "WFS",
>>                typename: "villages",
>>                request: "getfeature",
>>                version: "1.0.0"
>>                 extractAttributes: true
>> Attempt with the params moved into the URL:
ILTER=nomos='Eleia'&typename=villages&request=getfeature&version=1.0.0&servi
ce=wfs",{
>>                 styleMap: oStyleMap
>> From: Andreas Hocevar [mailto:andreas.hocevar at gmail.com]
>> Sent: Wed 8/13/2008 7:11 AM
>> To: Eric Lemoine
>> Cc: Brenningmeyer, Todd; Openlayers Users List
>> Hi,
>> On Wed, Aug 13, 2008 at 2:08 PM, Eric Lemoine <eric.c2c at gmail.com>
>> wrote:
>>> On Wed, Aug 13, 2008 at 11:49 AM, Andreas Hocevar
>>> <andreas.hocevar at gmail.com> wrote:
>>>> Hi,
>>>> Since CQL_FILTER is not part to the WMS spec, the best way is to
>>>> add the filter to the WMS url, e.g.
>>>> var layer=new OpenLayers.Layer.WMS("cql",
>>>> "http://your-server/wms?CQL_FILTER=foo<3", params, options);
>>> Todd's question related to WFS, but I guess the response is similar,
>>> isn't it?
>> Should be, yes. Just s/WMS/WFS/gi.
>> Regards,
>> Andreas.
>> No virus found in this incoming message.
>> Checked by AVG - http://www.avg.com <http://www.avg.com/>
>> <http://www.avg.com/> <http://www.avg.com/>
>> Version: 8.0.138 / Virus Database: 270.6.2/1609 - Release Date:
>> 8/13/2008
>> 6:43 AM
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Users mailing list
