[OpenLayers-Users] CQL queries with WFS
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Thu Aug 14 15:53:33 EDT 2008
Hi Arnd,
good catch, it does not. Geoserver does.
Best regards,
Bart
Arnd Wippermann wrote:
> Hi,
> Does MapServer support CQL? If so I would be interested. Can someone point
> me to a source, how to use it? Internet search shows nothing for MapServer.
> Arnd Wippermann
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von Brenningmeyer, Todd
> Gesendet: Donnerstag, 14. August 2008 17:19
> An: bartvde at osgis.nl
> Cc: Openlayers Users List
> Betreff: Re: [OpenLayers-Users] CQL queries with WFS
> I used the code below but the map still returned all of the villages.  It
> seems very strange that both my CQL_Filter and URL style filters aren't
> working.  I'm sure I'm missing something but the filter process just doesn't
> seem to like my queries (at least in terms of the syntax I'm using).  The
> CQL_Filter params did appear in the params section within firebug when I ran
> it but in a vertical format with each letter listed after a number...so 0 C
> 1 Q 2 L and so on in a vertical column.  I'm not sure if this makes sense or
> if it is important to the filter problem.  Thanks again for your help.  If
> you have any other suggestions about using the CQL_FILTER or a URL style
> filter please let me know.  I've been tinkering with this for quite a while
> without success so your help is very much appreciated.
> Thanks again,
> Todd
> var wfsLayer = new OpenLayers.Layer.WFS( "villages",
> "http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&typen
> ame=villages&request=getfeature&version=1.0.0&service=wfs&",
>     styleMap: oStyleMap
> var value = "nomos='Eleia'";
> wfsLayer.mergeNewParams('CQL_FILTER:' + escape(value));  (I've used both :
> and = after CQL_FILTER but neither seemed to work)
> ________________________________
> From: bartvde at osgis.nl [mailto:bartvde at osgis.nl]
> Sent: Thu 8/14/2008 9:23 AM
> To: Brenningmeyer, Todd
> Cc: bartvde at osgis.nl; Andreas Hocevar; Eric Lemoine; Openlayers Users List
> Subject: RE: [OpenLayers-Users] CQL queries with WFS
> Can you try something like:
> http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&typena
> me=villages&request=getfeature&version=1.0.0&service=wfs&,{
>     styleMap: oStyleMap
> wfsLayer.mergeNewParams({'CQL_FILTER', escape(value)});
> Best regards,
> Bart
>> Bart,
>> I tried escaping the quotes around the value of the nomos but
>> unfortunately it didn't change the returned results.  I used
>> backslashes in front of the single quotes around Eleia.  Is this what you
> had in mind?
>>  It may be that I'm not escaping the right part of the filter.
>> Thanks,
>> Todd
> http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&CQL_FI
> LTER=nomos=\'Eleia\'&typename=villages&request=getfeature&version=1.0.0&serv
> ice=wfs,{
>>                 styleMap: oStyleMap
>> Sent: Thu 8/14/2008 8:52 AM
>> Cc: Andreas Hocevar; Eric Lemoine; Openlayers Users List
>> Subject: Re: [OpenLayers-Users] CQL queries with WFS
>> Have you tried escaping the value of your parameter CQL_FILTER?
>> Best regards,
>> Bart
>>> Thanks Andreas and Eric.  I've tried a few different options with the
>>> filter but without success.  I'm using the following filter and have
>>> tried this with the map location moved into the params section and a
>>> few other times with everything in a single URL request but still no
>>> luck.  The request returns all of the villages with none of these
>>> filtered out.  If you have any ideas that might help please let me
>>> know.  Thanks again for your help.
>>> Todd
> "http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&CQL_F
> ILTER=nomos='Eleia'
>>> <http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.ma
>>> p&CQL_FILTER=nomos='Eleia',{//
>>> p&CQL_FILTER=nomos='Eleia',{//<Filter> >
>>>> <PropertyIsEqualTo><PropertyName>nom_nr</PropertyName><Literal>39</L
>>>> iteral></PropertyIsEqualTo></Filter>
>>>                service: "WFS",
>>>                typename: "villages",
>>>                request: "getfeature",
>>>                version: "1.0.0"
>>>                 extractAttributes: true
>>> Attempt with the params moved into the URL:
> ILTER=nomos='Eleia'&typename=villages&request=getfeature&version=1.0.0&servi
> ce=wfs",{
>>>                 styleMap: oStyleMap
>>> From: Andreas Hocevar [mailto:andreas.hocevar at gmail.com]
>>> Sent: Wed 8/13/2008 7:11 AM
>>> To: Eric Lemoine
>>> Cc: Brenningmeyer, Todd; Openlayers Users List
>>> Hi,
>>> On Wed, Aug 13, 2008 at 2:08 PM, Eric Lemoine <eric.c2c at gmail.com>
>>> wrote:
>>>> On Wed, Aug 13, 2008 at 11:49 AM, Andreas Hocevar
>>>> <andreas.hocevar at gmail.com> wrote:
>>>>> Hi,
>>>>> Since CQL_FILTER is not part to the WMS spec, the best way is to
>>>>> add the filter to the WMS url, e.g.
>>>>> var layer=new OpenLayers.Layer.WMS("cql",
>>>>> "http://your-server/wms?CQL_FILTER=foo<3", params, options);
>>>> Todd's question related to WFS, but I guess the response is similar,
>>>> isn't it?
>>> Should be, yes. Just s/WMS/WFS/gi.
>>> Regards,
>>> Andreas.
>>> No virus found in this incoming message.
>>> Checked by AVG - http://www.avg.com <http://www.avg.com/>
>>> <http://www.avg.com/> <http://www.avg.com/>
>>> Version: 8.0.138 / Virus Database: 270.6.2/1609 - Release Date:
>>> 8/13/2008
>>> 6:43 AM
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
> Users mailing list
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
