[OpenLayers-Users] CQL queries with WFS
Josh Marcus jmarcus at avencia.com
Thu Aug 14 15:57:59 EDT 2008
Arnd,
While MapServer does not support CQL specifically, most CQL filters will
work as MapServer filters -- and MapServer filters have some capabilities
beyond what CQL will support.  But a basic CQL filter (e.g. just checking
for equality or greater than or less than) will work unchanged under
Mapsever.
--j
On Thu, Aug 14, 2008 at 3:50 PM, Arnd Wippermann <arnd.wippermann at web.de>wrote:
> Hi,
> Does MapServer support CQL? If so I would be interested. Can someone point
> me to a source, how to use it? Internet search shows nothing for MapServer.
> Arnd Wippermann
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von Brenningmeyer, Todd
> Gesendet: Donnerstag, 14. August 2008 17:19
> An: bartvde at osgis.nl
> Cc: Openlayers Users List
> Betreff: Re: [OpenLayers-Users] CQL queries with WFS
> I used the code below but the map still returned all of the villages.  It
> seems very strange that both my CQL_Filter and URL style filters aren't
> working.  I'm sure I'm missing something but the filter process just
> doesn't
> seem to like my queries (at least in terms of the syntax I'm using).  The
> CQL_Filter params did appear in the params section within firebug when I
> ran
> it but in a vertical format with each letter listed after a number...so 0 C
> 1 Q 2 L and so on in a vertical column.  I'm not sure if this makes sense
> or
> if it is important to the filter problem.  Thanks again for your help.  If
> you have any other suggestions about using the CQL_FILTER or a URL style
> filter please let me know.  I've been tinkering with this for quite a while
> without success so your help is very much appreciated.
> Thanks again,
> Todd
> var wfsLayer = new OpenLayers.Layer.WFS( "villages",
> http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&typen
> ame=villages&request=getfeature&version=1.0.0&service=wfs&<http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&typename=villages&request=getfeature&version=1.0.0&service=wfs&>
>    styleMap: oStyleMap
> var value = "nomos='Eleia'";
> wfsLayer.mergeNewParams('CQL_FILTER:' + escape(value));  (I've used both :
> and = after CQL_FILTER but neither seemed to work)
> ________________________________
> From: bartvde at osgis.nl [mailto:bartvde at osgis.nl]
> Sent: Thu 8/14/2008 9:23 AM
> To: Brenningmeyer, Todd
> Cc: bartvde at osgis.nl; Andreas Hocevar; Eric Lemoine; Openlayers Users List
> Subject: RE: [OpenLayers-Users] CQL queries with WFS
> Can you try something like:
> me=villages&request=getfeature&version=1.0.0&service=wfs&,{<http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&typename=villages&request=getfeature&version=1.0.0&service=wfs&,%7B>
>    styleMap: oStyleMap
> wfsLayer.mergeNewParams({'CQL_FILTER', escape(value)});
> Best regards,
> Bart
> > Bart,
> > I tried escaping the quotes around the value of the nomos but
> > unfortunately it didn't change the returned results.  I used
> > backslashes in front of the single quotes around Eleia.  Is this what you
> had in mind?
> >  It may be that I'm not escaping the right part of the filter.
> > Thanks,
> > Todd
> http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&CQL_FI
> LTER=nomos=\'Eleia\'&typename=villages&request=getfeature&version=1.0.0&serv
> ice=wfs,{<http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&CQL_FILTER=nomos=%5C%27Eleia%5C%27&typename=villages&request=getfeature&version=1.0.0&service=wfs,%7B>
> >                 styleMap: oStyleMap
> > Sent: Thu 8/14/2008 8:52 AM
> > Cc: Andreas Hocevar; Eric Lemoine; Openlayers Users List
> > Subject: Re: [OpenLayers-Users] CQL queries with WFS
> > Have you tried escaping the value of your parameter CQL_FILTER?
> > Best regards,
> > Bart
> >> Thanks Andreas and Eric.  I've tried a few different options with the
> >> filter but without success.  I'm using the following filter and have
> >> tried this with the map location moved into the params section and a
> >> few other times with everything in a single URL request but still no
> >> luck.  The request returns all of the villages with none of these
> >> filtered out.  If you have any ideas that might help please let me
> >> know.  Thanks again for your help.
> >> Todd
> ILTER=nomos='Eleia<http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&CQL_FILTER=nomos=%27Eleia>
> >> p&CQL_FILTER=nomos='Eleia',{//
> >> p&CQL_FILTER=nomos='Eleia',{//<Filter> >
> >> ><PropertyIsEqualTo><PropertyName>nom_nr</PropertyName><Literal>39</L
> >> >iteral></PropertyIsEqualTo></Filter>
> >>                service: "WFS",
> >>                typename: "villages",
> >>                request: "getfeature",
> >>                version: "1.0.0"
> >>                 extractAttributes: true
> >> Attempt with the params moved into the URL:
> ILTER=nomos='Eleia'&typename=villages&request=getfeature&version=1.0.0&servi
> ce=wfs",{
> >>                 styleMap: oStyleMap
> >> From: Andreas Hocevar [mailto:andreas.hocevar at gmail.com]
> >> Sent: Wed 8/13/2008 7:11 AM
> >> To: Eric Lemoine
> >> Cc: Brenningmeyer, Todd; Openlayers Users List
> >> Hi,
> >> On Wed, Aug 13, 2008 at 2:08 PM, Eric Lemoine <eric.c2c at gmail.com>
> >> wrote:
> >>> On Wed, Aug 13, 2008 at 11:49 AM, Andreas Hocevar
> >>> <andreas.hocevar at gmail.com> wrote:
> >>>> Hi,
> >>>> Since CQL_FILTER is not part to the WMS spec, the best way is to
> >>>> add the filter to the WMS url, e.g.
> >>>> var layer=new OpenLayers.Layer.WMS("cql",
> >>>> "http://your-server/wms?CQL_FILTER=foo<3", params, options);
> >>> Todd's question related to WFS, but I guess the response is similar,
> >>> isn't it?
> >> Should be, yes. Just s/WMS/WFS/gi.
> >> Regards,
> >> Andreas.
> >> No virus found in this incoming message.
> >> Checked by AVG - http://www.avg.com <http://www.avg.com/>
> >> <http://www.avg.com/> <http://www.avg.com/>
> >> Version: 8.0.138 / Virus Database: 270.6.2/1609 - Release Date:
> >> 8/13/2008
> >> 6:43 AM
> >> _______________________________________________
> >> Users mailing list
> >> Users at openlayers.org
> >> http://openlayers.org/mailman/listinfo/users
> Users mailing list
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080814/62d4d67c/attachment.html
