[OpenLayers-Users] CQL queries with WFS
Josh Marcus jmarcus at avencia.com
Thu Aug 14 16:03:01 EDT 2008
By the way, here is a brief documentation reference about how to apply a
filter:
Look at:
http://ms.gis.umn.edu/docs/reference/mapfile/layer
and search for "FILTER".
So, for example, you might achieve the same result as passing in the
following CGI variable to a GeoServer WMS call:
CQL_FILTER="attribute > 50"
... by passing the following CGI variable to a MapServer WMS call:
MAP_LAYER_0_FILTER="attribute > 50"
--j
On Thu, Aug 14, 2008 at 3:57 PM, Josh Marcus <jmarcus at avencia.com> wrote:
> Arnd,
> While MapServer does not support CQL specifically, most CQL filters will
> work as MapServer filters -- and MapServer filters have some capabilities
> beyond what CQL will support.  But a basic CQL filter (e.g. just checking
> for equality or greater than or less than) will work unchanged under
> Mapsever.
> --j
> On Thu, Aug 14, 2008 at 3:50 PM, Arnd Wippermann <arnd.wippermann at web.de>wrote:
>> Hi,
>> Does MapServer support CQL? If so I would be interested. Can someone point
>> me to a source, how to use it? Internet search shows nothing for
>> MapServer.
>> Arnd Wippermann
>> -----Ursprüngliche Nachricht-----
>> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
>> Im
>> Auftrag von Brenningmeyer, Todd
>> Gesendet: Donnerstag, 14. August 2008 17:19
>> An: bartvde at osgis.nl
>> Cc: Openlayers Users List
>> Betreff: Re: [OpenLayers-Users] CQL queries with WFS
>> I used the code below but the map still returned all of the villages.  It
>> seems very strange that both my CQL_Filter and URL style filters aren't
>> working.  I'm sure I'm missing something but the filter process just
>> doesn't
>> seem to like my queries (at least in terms of the syntax I'm using).  The
>> CQL_Filter params did appear in the params section within firebug when I
>> ran
>> it but in a vertical format with each letter listed after a number...so 0
>> C
>> 1 Q 2 L and so on in a vertical column.  I'm not sure if this makes sense
>> or
>> if it is important to the filter problem.  Thanks again for your help.  If
>> you have any other suggestions about using the CQL_FILTER or a URL style
>> filter please let me know.  I've been tinkering with this for quite a
>> while
>> without success so your help is very much appreciated.
>> Thanks again,
>> Todd
>> var wfsLayer = new OpenLayers.Layer.WFS( "villages",
>> http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&typen
>> ame=villages&request=getfeature&version=1.0.0&service=wfs&<http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&typename=villages&request=getfeature&version=1.0.0&service=wfs&>
>>    styleMap: oStyleMap
>> var value = "nomos='Eleia'";
>> wfsLayer.mergeNewParams('CQL_FILTER:' + escape(value));  (I've used both :
>> and = after CQL_FILTER but neither seemed to work)
>> ________________________________
>> From: bartvde at osgis.nl [mailto:bartvde at osgis.nl]
>> Sent: Thu 8/14/2008 9:23 AM
>> To: Brenningmeyer, Todd
>> Cc: bartvde at osgis.nl; Andreas Hocevar; Eric Lemoine; Openlayers Users
>> List
>> Subject: RE: [OpenLayers-Users] CQL queries with WFS
>> Can you try something like:
>> me=villages&request=getfeature&version=1.0.0&service=wfs&,{<http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&typename=villages&request=getfeature&version=1.0.0&service=wfs&,%7B>
>>    styleMap: oStyleMap
>> wfsLayer.mergeNewParams({'CQL_FILTER', escape(value)});
>> Best regards,
>> Bart
>> > Bart,
>> > I tried escaping the quotes around the value of the nomos but
>> > unfortunately it didn't change the returned results.  I used
>> > backslashes in front of the single quotes around Eleia.  Is this what
>> you
>> had in mind?
>> >  It may be that I'm not escaping the right part of the filter.
>> > Thanks,
>> > Todd
>> http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&CQL_FI
>> LTER=nomos=\'Eleia\'&typename=villages&request=getfeature&version=1.0.0&serv
>> ice=wfs,{<http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&CQL_FILTER=nomos=%5C%27Eleia%5C%27&typename=villages&request=getfeature&version=1.0.0&service=wfs,%7B>
>> >                 styleMap: oStyleMap
>> > Sent: Thu 8/14/2008 8:52 AM
>> > Cc: Andreas Hocevar; Eric Lemoine; Openlayers Users List
>> > Subject: Re: [OpenLayers-Users] CQL queries with WFS
>> > Have you tried escaping the value of your parameter CQL_FILTER?
>> > Best regards,
>> > Bart
>> >> Thanks Andreas and Eric.  I've tried a few different options with the
>> >> filter but without success.  I'm using the following filter and have
>> >> tried this with the map location moved into the params section and a
>> >> few other times with everything in a single URL request but still no
>> >> luck.  The request returns all of the villages with none of these
>> >> filtered out.  If you have any ideas that might help please let me
>> >> know.  Thanks again for your help.
>> >> Todd
>> ILTER=nomos='Eleia<http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&CQL_FILTER=nomos=%27Eleia>
>> >> p&CQL_FILTER=nomos='Eleia',{//
>> >> p&CQL_FILTER=nomos='Eleia',{//<Filter> >
>> >> ><PropertyIsEqualTo><PropertyName>nom_nr</PropertyName><Literal>39</L
>> >> >iteral></PropertyIsEqualTo></Filter>
>> >>                service: "WFS",
>> >>                typename: "villages",
>> >>                request: "getfeature",
>> >>                version: "1.0.0"
>> >>                 extractAttributes: true
>> >> Attempt with the params moved into the URL:
>> ILTER=nomos='Eleia'&typename=villages&request=getfeature&version=1.0.0&servi
>> ce=wfs",{
>> >>                 styleMap: oStyleMap
>> >> From: Andreas Hocevar [mailto:andreas.hocevar at gmail.com]
>> >> Sent: Wed 8/13/2008 7:11 AM
>> >> To: Eric Lemoine
>> >> Cc: Brenningmeyer, Todd; Openlayers Users List
>> >> Hi,
>> >> On Wed, Aug 13, 2008 at 2:08 PM, Eric Lemoine <eric.c2c at gmail.com>
>> >> wrote:
>> >>> On Wed, Aug 13, 2008 at 11:49 AM, Andreas Hocevar
>> >>> <andreas.hocevar at gmail.com> wrote:
>> >>>> Hi,
>> >>>> Since CQL_FILTER is not part to the WMS spec, the best way is to
>> >>>> add the filter to the WMS url, e.g.
>> >>>> var layer=new OpenLayers.Layer.WMS("cql",
>> >>>> "http://your-server/wms?CQL_FILTER=foo<3", params, options);
>> >>> Todd's question related to WFS, but I guess the response is similar,
>> >>> isn't it?
>> >> Should be, yes. Just s/WMS/WFS/gi.
>> >> Regards,
>> >> Andreas.
>> >> No virus found in this incoming message.
>> >> Checked by AVG - http://www.avg.com <http://www.avg.com/>
>> >> <http://www.avg.com/> <http://www.avg.com/>
>> >> Version: 8.0.138 / Virus Database: 270.6.2/1609 - Release Date:
>> >> 8/13/2008
>> >> 6:43 AM
>> >> _______________________________________________
>> >> Users mailing list
>> >> Users at openlayers.org
>> >> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
>> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080814/8533d9ae/attachment.html
