[OpenLayers-Users] New to openlayers - problem with multiple layers
ajohnson at ecotropolis.com ajohnson at ecotropolis.com
Mon Aug 18 12:11:30 EDT 2008
Thanks!
> On Sun, Aug 17, 2008 at 03:50:20PM -0400, ajohnson at ecotropolis.com wrote:
>> Is there some way around it? I have several layers for various states,
>> and
>> they are all in different projections.
> Your WMS server probably supports reprojection. The problem in this
> particular ase seems likely to be that you're displaying the MetaCarta
> Labs MapServer WMS mixed in, which *doesn't* support reprojection.
> You'll need to pick a single projection to display in, the same way you
> would in any interface, but once you pick one I expect GeoServer will do
> all the work for you. Just stop using a MapServer-served
> layer that's not configured to do that :)
>> Amy Johnson
>> > On Sat, Aug 16, 2008 at 07:23:35PM -0400, ajohnson at ecotropolis.com
>> wrote:
>> >> Hello,
>> >> I am trying to display multiple layers with different EPSGs.I keep
>> >> getting
>> >> the following error:
>> >> msWMSLoadGetMapParams(): Invalid SRS given SRS must be valid for all
>> >> requested layers.
>> >> I googled the error, but couldn't seem to find anything that helped
>> me.
>> >> My code is below. Any help in understanding what I'm doing wrong is
>> >> appreciated.
>> > You can't display multiple layers with different projections at the
>> same
>> > time in OpenLayers.
>> > Regards,
>> > Christopher Schmidt
>> > MetaCarta
> Christopher Schmidt
> MetaCarta
