[OpenLayers-Users] Popups on Point Track Markers..
David Calle davydky at gmail.com
Mon Aug 18 12:47:16 EDT 2008
Hi Dear List...
I'm using the example "Poin Track Markers".
But I need to modify the popups of the Markers...
[1] How can I set the content, because on the example only <title> and
<description> appears.
[2] How can I set the the visual properties(size, transparency, etc)
This is the format of my xml file:
<item>
           <geo:lat>-2.8849877900038</geo:lat>
           <geo:long>-79.0611279883398</geo:long>
           <title>2008-08-01 05:08:48 hrs.</title>
          <description>16.540 Km/h.</description>
</item>
So,  I want to set the popup content with that.
[3] Finally I want to set the Track Visual Properties.. (color, size, etc).
Thanks..!!  =).
PD: this is the code..(Points and Track)
      function addUrl()
            ejecutarsql(OpenLayers.Util.getElement('unidad').value);
                var urlObj = OpenLayers.Util.getElement('url');
                var value = urlObj.value;
                var parts = value.split("/");
                rss = new OpenLayers.Layer.GeoRSS(parts[parts.length-1],
value);
                rss.events.register("loadend", window, populateMap);
                map.addLayer(rss);
        function populateMap()
                var lineLayer = new OpenLayers.Layer.PointTrack(rss.name + "
Track",
                        {dataFrom:
OpenLayers.Layer.PointTrack.dataFrom.SOURCE_NODE});
            lineLayer.addNodes(rss.features);
            map.addLayer(lineLayer);
            rss.setName("Points");
            var feature, marker;
                for (var i = rss.features.length-1; i>0; i--)
                         if
(rss.features[i].data.popupContentHTML.indexOf("Untitled")!= -1)
                 {rss.removeMarker(rss.markers[i]);}
                map.raiseLayer(rss, 1);
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080818/a9c74ebc/attachment.html
