[OpenLayers-Users] Identifier working on Firefox, not IE7?
Xiaoyu Guan guanxiaoyu at gmail.com
Tue Aug 19 03:49:17 EDT 2008
Dear All:
I use Geoserver + Tilecache + Openlayers. I have a identifier which only
work on Firefox. but on IE7 , not sure about IE6.
What I did, I have four Layers , two TileCache layers, two Geoserver layers.
I hide two geoserver layers in layerswitcher. People in the map viewer only
can get TileCache layers. I can use WMS getfeatureinfo from Geoserver. the
identifier is base on Geoserver. some poeple told me that IE and Firefox is
different when they reading an array. I have check my script for many times.
but still cannot figure it out. Is there anybody can help me to figure it
out?
/* Copyright (c) 2006-2007 MetaCarta, Inc., published under the BSD license.
 * See http://svn.openlayers.org/trunk/openlayers/release-license.txt
 * for the full text of the license. */
 * @requires OpenLayers/Control.js
 * Class: OpenLayers.Control.FeatureInfo
 * Inherits from:
 *  - <OpenLayers.Control>
OpenLayers.Control.FeatureInfo = OpenLayers.Class(OpenLayers.Control, {
    requestURL: null,
    initialize: function(options) {
        OpenLayers.Control.Panel.prototype.initialize.apply(this,
[options]);
    destroy: function() {
        this.map.events.unregister( 'click', this, this.getFeatureInfo );
        OpenLayers.Control.prototype.destroy.apply(this, arguments);
        draw: function() {
        OpenLayers.Control.prototype.draw.apply(this, arguments);
        return this.div;
    activate: function() {
        if (OpenLayers.Control.prototype.activate.apply(this, arguments)) {
            this.map.events.register('click', this, this.getFeatureInfo);
            return true;
        }else{
            return false;
    deactivate: function() {
        if (OpenLayers.Control.prototype.deactivate.apply(this, arguments))
            return true;
        } else {
            return false;
    getFeatureInfo:function(evt){
                if (!OpenLayers.Event.isLeftClick(evt)) return;
                /* Here I removed two TileCache Layers from map.layers
Maybe the reason is I use slice
                var url =  this.map.layers.slice(2)[0].getFullRequestString(
                        REQUEST: "GetFeatureInfo",
                        EXCEPTIONS: "application/vnd.ogc.se_xml",
                        BBOX:
this.map.layers.slice(2)[0].map.getExtent().toBBOX(),
                        X: evt.xy.x,
                        Y: evt.xy.y,
                        INFO_FORMAT: 'text/html',
                        QUERY_LAYERS:
this.map.layers.slice(2)[0].params.LAYERS,
                        FEATURE_COUNT: 50,
                        WIDTH: this.map.size.w,
                        HEIGHT: this.map.size.h
                "http://127.0.0.1:2008/geoserver/wms"
                OpenLayers.loadURL(url, '', this,
                function(response) {
                var lonlat = this.map.getLonLatFromViewPortPx(evt.xy);
                var popup = new OpenLayers.Popup.AnchoredBubble(
                    " ",lonlat, null, response.responseText, null, true);
                this.map.addPopup(popup, true );
         OpenLayers.Event.stop(evt);
    CLASS_NAME: "OpenLayers.Control.FeatureInfo"
Here is some related information about my script
http://www.nabble.com/TileCache-%2B-GetFeatureinfo(Geoserver1.6.4)--td18753089.html
All the best
Xiaoyu
Xiaoyu Guan (Sam)
Geo-information Science
Wageningen UR
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080819/1dab63f1/attachment.html
