[OpenLayers-Users] Identifier working on Firefox, not IE7?
Xiaoyu Guan guanxiaoyu at gmail.com
Tue Aug 19 10:20:25 EDT 2008
Dear All
I found the problem by using JSLint,
it works in IE7 after removing
if (!OpenLayers.Event.isLeftClick(evt)) return;
All the best
Xiaoyu
On Tue, Aug 19, 2008 at 9:49 AM, Xiaoyu Guan <guanxiaoyu at gmail.com> wrote:
> Dear All:
> I use Geoserver + Tilecache + Openlayers. I have a identifier which only
> work on Firefox. but on IE7 , not sure about IE6.
> What I did, I have four Layers , two TileCache layers, two Geoserver
> layers. I hide two geoserver layers in layerswitcher. People in the map
> viewer only can get TileCache layers. I can use WMS getfeatureinfo from
> Geoserver. the identifier is base on Geoserver. some poeple told me that IE
> and Firefox is different when they reading an array. I have check my script
> for many times. but still cannot figure it out. Is there anybody can help me
> to figure it out?
> /* Copyright (c) 2006-2007 MetaCarta, Inc., published under the BSD
> license.
>  * See http://svn.openlayers.org/trunk/openlayers/release-license.txt
>  * for the full text of the license. */
>  * @requires OpenLayers/Control.js
>  * Class: OpenLayers.Control.FeatureInfo
>  * Inherits from:
>  *  - <OpenLayers.Control>
> OpenLayers.Control.FeatureInfo = OpenLayers.Class(OpenLayers.Control, {
>     requestURL: null,
>     initialize: function(options) {
>         OpenLayers.Control.Panel.prototype.initialize.apply(this,
> [options]);
>     destroy: function() {
>         this.map.events.unregister( 'click', this, this.getFeatureInfo );
>         OpenLayers.Control.prototype.destroy.apply(this, arguments);
>         draw: function() {
>         OpenLayers.Control.prototype.draw.apply(this, arguments);
>         return this.div;
>     activate: function() {
>         if (OpenLayers.Control.prototype.activate.apply(this, arguments)) {
>             this.map.events.register('click', this, this.getFeatureInfo);
>             return true;
>         }else{
>             return false;
>     deactivate: function() {
>         if (OpenLayers.Control.prototype.deactivate.apply(this, arguments))
>             return true;
>         } else {
>             return false;
>     getFeatureInfo:function(evt){
>                 /* Here I removed two TileCache Layers from map.layers
> Maybe the reason is I use slice
>                 var url =
> this.map.layers.slice(2)[0].getFullRequestString(
>                         REQUEST: "GetFeatureInfo",
>                         EXCEPTIONS: "application/vnd.ogc.se_xml",
>                         BBOX:
> this.map.layers.slice(2)[0].map.getExtent().toBBOX(),
>                         X: evt.xy.x,
>                         Y: evt.xy.y,
>                         INFO_FORMAT: 'text/html',
>                         QUERY_LAYERS:
> this.map.layers.slice(2)[0].params.LAYERS,
>                         FEATURE_COUNT: 50,
>                         WIDTH: this.map.size.w,
>                         HEIGHT: this.map.size.h
>                 "http://127.0.0.1:2008/geoserver/wms"
>                 OpenLayers.loadURL(url, '', this,
>                 function(response) {
>                 var lonlat = this.map.getLonLatFromViewPortPx(evt.xy);
>                 var popup = new OpenLayers.Popup.AnchoredBubble(
>                     " ",lonlat, null, response.responseText, null, true);
>                 this.map.addPopup(popup, true );
>          OpenLayers.Event.stop(evt);
>     CLASS_NAME: "OpenLayers.Control.FeatureInfo"
> Here is some related information about my script
> http://www.nabble.com/TileCache-%2B-GetFeatureinfo(Geoserver1.6.4)--td18753089.html<http://www.nabble.com/TileCache-%2B-GetFeatureinfo%28Geoserver1.6.4%29--td18753089.html>
> All the best
> Xiaoyu
> Xiaoyu Guan (Sam)
> Geo-information Science
> Wageningen UR
Xiaoyu Guan (Sam)
Wageningen UR
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080819/19221392/attachment.html
