[OpenLayers-Users] WMS and Google Maps - Overlayer Alignement
Salvaro asufsc at gmail.com
Mon Aug 25 10:14:37 EDT 2008
Sure.
When I set this option (Spherical Mercator true), I can't move the map (or
use the pan scan).
I'm using map Options with these configs:
maxResolution: 156543.0339
maxExtent: -20037508., -20037508.34, 20037508.34, 20037508.34
NumZoomLevels: 19
Units: m
Projection: "EPSG:900913"
displayProjection: new Projection("EPSG:4326") (tried without this too)
And using the layer with simple config (type, isBaseLayer and spherical
mercator).
Anything wrong?
Thanks!
Salvaro.
Christopher Schmidt-2 wrote:
> On Mon, Aug 25, 2008 at 06:47:46AM -0700, Salvaro wrote:
>> Hey,
>> I've a map where I put three layers, WMS, Google Maps and vector Layer
>> with
>> data.
>> When I'm using the WMS layer, the vector Layer works well and project the
>> points in correct position.
>> But using Google Maps when I change the position of the map, the points
>> in
>> vector Layer changes their position too (they "walk"  up or down),
>> changing
>> the latitude (the longitude works well). I tested much things to change
>> the
>> projection, set the projection in layer, in map, display projection, but
>> nothing works well. Anyone knows what I've to do to correct this?
> The sphericalMercator: true option (which you've described as being
> problematic below) is the solution to this. Vectors don't work over
> google except in sphericalMercator.
>> Another problem is when I set "Spherical Mercator"  true in Google layer.
>> Don't know why, but the controls doesn't work after this (including after
>> I
>> set the displayProjection).
> Can you include a small example of this problem? I don't kno why this
> would be, but this is what you'll need to resolve.
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/WMS-and-Google-Maps---Overlayer-Alignement-tp781460p781508.html
