[OpenLayers-Users] WMS and Google Maps - Overlayer Alignement
Christopher Schmidt crschmidt at metacarta.com
Mon Aug 25 09:58:55 EDT 2008
On Mon, Aug 25, 2008 at 06:47:46AM -0700, Salvaro wrote:
> Hey,
> I've a map where I put three layers, WMS, Google Maps and vector Layer with
> data.
> When I'm using the WMS layer, the vector Layer works well and project the
> points in correct position.
> But using Google Maps when I change the position of the map, the points in
> vector Layer changes their position too (they "walk"  up or down), changing
> the latitude (the longitude works well). I tested much things to change the
> projection, set the projection in layer, in map, display projection, but
> nothing works well. Anyone knows what I've to do to correct this?
The sphericalMercator: true option (which you've described as being
problematic below) is the solution to this. Vectors don't work over
google except in sphericalMercator.
> Another problem is when I set "Spherical Mercator"  true in Google layer.
> Don't know why, but the controls doesn't work after this (including after I
> set the displayProjection).
Can you include a small example of this problem? I don't kno why this
would be, but this is what you'll need to resolve.
Regards,
Christopher Schmidt
MetaCarta
