[OpenLayers-Users] WMS and Google Maps - Overlayer Alignement
Salvaro asufsc at gmail.com
Mon Aug 25 10:56:17 EDT 2008
Right. I didn't post the JS because I'm programming direct in Java using
gwt+openlayers.
I'm trying to get the generated JS code (and check if it's correct) and
after will post here.
Thanks mate.
Christopher Schmidt-2 wrote:
> On Mon, Aug 25, 2008 at 07:14:37AM -0700, Salvaro wrote:
>> Sure.
>> When I set this option (Spherical Mercator true), I can't move the map
>> (or
>> use the pan scan).
>> I'm using map Options with these configs:
>> maxResolution: 156543.0339
>> maxExtent: -20037508., -20037508.34, 20037508.34, 20037508.34
>> NumZoomLevels: 19
>> Units: m
>> Projection: "EPSG:900913"
>> displayProjection: new Projection("EPSG:4326") (tried without this too)
>> And using the layer with simple config (type, isBaseLayer and spherical
>> mercator).
> Since you didn't include Javascript, it's hard to know. :)
> Please publish (on the web) or attach to email an HTML file which
> demonstrates the problem. What you've just described is also true of
> http://openlayers.org/dev/examples/spherical-mercator.html , which works
> fine.
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/WMS-and-Google-Maps---Overlayer-Alignement-tp781460p781654.html
