[OpenLayers-Users] Layer selection in LayerSwitcher
Eric Lemoine eric.c2c at gmail.com
Thu Aug 28 13:16:29 EDT 2008
Hi. The layer switcher control isn't meant for changing layer opacity.
You'll have to implement your own GUI here. Eric
2008/8/28, Bas Couwenberg <bascouwenberg at gmail.com>:
> Hello,
> is it possbile with the LayerSwitcher control to select a layer (I don't
> mean turn invisible) which I then could use to change it opacity. The
> opacity part works well from the examples but I want to do this per layer I
> select.
> Best regards,
> Bas Couwenberg
