[OpenLayers-Users] Layer selection in LayerSwitcher
Erik Uzureau euzuro at gmail.com
Thu Aug 28 13:26:52 EDT 2008
It's true. The default layer switcher does not contain GUI for
handling individual layer opacities.
That said, I am *sure* that I have seen a custom layer switcher at
some point which was designed
to be used with OpenLayers that *did* do exactly what you are desiring.
Unfortunately, I don't remember where I saw it. Maybe someone else on
this list does?
Erik
On Thu, Aug 28, 2008 at 12:16 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
> Hi. The layer switcher control isn't meant for changing layer opacity.
> You'll have to implement your own GUI here. Eric
> 2008/8/28, Bas Couwenberg <bascouwenberg at gmail.com>:
>> Hello,
>> is it possbile with the LayerSwitcher control to select a layer (I don't
>> mean turn invisible) which I then could use to change it opacity. The
>> opacity part works well from the examples but I want to do this per layer I
>> select.
>> Best regards,
>> Bas Couwenberg
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
