[OpenLayers-Users] GML, Point and Change the Size of the Circle...
Kit Plummer kitplummer at gmail.com
Fri Aug 29 17:37:15 EDT 2008
On Aug 29, 2008, at 12:59 AM, Andreas Hocevar wrote:
> Kit Plummer wrote:
>> Ok, first let me plead practical ignorance here.  I've only been
>> working with OpenLayers for about a week.  And, I'm integrating it
>> into ExtJS.  I have a known GML file that contains Points.  I'd
>> like  to be able to add an attribute to each element that would
>> specify the  size of the circle that gets drawn by OL.  Am I out of
>> luck here?  If  not, would somebody be so nice as to point me in
>> the right direction?
> Have a look at http://www.openlayers.org/dev/examples/styles-rotation.html
> You will want to use a style map, and define the pointRadius
> property of the symbolizer. Say you have a field called "size" in
> your GML features. Then your stylemap constructor call could look
> like that:
> new OpenLayers.StyleMap({
>   "default": OpenLayers.Util.applyDefaults({
>       pointRadius: "${size}"
>   }, OpenLayers.Feature.Vector.style["default"]
> Regards,
> Andreas.
Ok, so that works...curious now if it is possible to make the
gml:points features so I can use a select like this:
var myStyles = new OpenLayers.StyleMap({
				"default": new OpenLayers.Style({
					pointRadius: "${size}", // sized according to size element from
GML source
					fillColor: "#ffcc66",
					strokeColor: "#ff9933",
					fillOpacity: 0.1,
					strokeWidth: 2
					"select": new OpenLayers.Style({
						fillColor: "#66ccff",
						strokeColor: "#3399ff"
			olmap.addLayer(new OpenLayers.Layer.GML("GML", gml, {styleMap:
myStyles}));
Thanks again.
Kit
