[OpenLayers-Users] KML from Geoserver
Laurent Pierre mail at lespierre.org
Sat Aug 30 08:53:11 EDT 2008
Andreas Hocevar wrote:
> Can you please try to paste the KML that fails into
> http://www.openlayers.org/dev/examples/vector-formats.html? Then set the
> format to KML, click "add feature" and see what happens. Just to make
> sure if this problem persists with the current trunk version.
> Or, if that is too much hassle, just send us the KML file that fails
> (not just a fragment, there should be at least one placemark in it for
> testing).
Hi Andreas,
I tested the file as indicated and I got the same results, due to the same 2
problems.  Anyway I send the file
http://n2.nabble.com/file/n793976/agences.kml agences.kml  with corrections
in comments.
Cheers
Laurent
View this message in context: http://n2.nabble.com/KML-from-Geoserver-tp789434p793976.html
