[OpenLayers-Users] OpenLayers with liter Window Dressing (lightwindow)
Lance Dyas lancelot at inetnebr.com
Sat Aug 30 11:52:00 EDT 2008
Christopher Schmidt wrote:
>>> On Fri, Aug 29, 2008 at 11:44:42PM -0500, Lance Dyas wrote:
>>>> I have been able to get OpenLayers to work with lightwindow, which is
>>>> based on prototype.js
>>>> however ...  this is one of the heaviest libraries... others based on
>>>> jQuery dont work due to incompatibilities of OL: with jquery..
>>>> has anyone found a lighter solution which works with OpenLayers?
>>> jQuery and OpenLayers can work fine together: it just requires a bit of
>>> effort
>> well thats not quite my definition of fine... if you  override JQueries
>> $ then you have to track
>> back whether it will still work with some library X derived of JQuery...
>> and if not then
>> you have to give JQuery an alternative $ (which JQuery has automated)
>> and modify the other library to use...yes a little effort
> Er, yes, I understand that. It's unfortunate that this is the case, but
> it doesn't mean that "jQuery doesn't work with OpenLayers". You just
> need to do "$ = jQuery.noConflict();"
Which ends up being very handy.... umm will OpenLayers work if you
actually define the  $ back to JQueries?
I used the "J$  = jQuery.noConflict();"
> Also, I think that any jQuery library which *depends* on '$' is probably
> buggy. (So is any OpenLayers-based library that depends on "$", for the
> record.) But of course that doesn't mean that no library is buggy in
> this way.  *shrug*
 Yes they do indeed depend on it
