[OpenLayers-Users] GeoJSON layer and modifyFeature control
Adorian Ardelean mynature at gmail.com
Thu Dec 4 04:17:26 EST 2008
Hi Jan,
In test case, it does not work even if I have only one layer and one
modifyFeature control (no other selectFeature and modifyFeature controls).
In real application case, I switch (one-at-a-time)  among controls using an
external form and multiple selection controls work on the two distinct
layers (let say I have several selectFeature controls to get feature infos
in various layers). Only the modifyFeature on the GeoJSON layer does not
work.
All the best,
Adorian
On Thu, Dec 4, 2008 at 9:54 AM, Jan van der Ven <j.vanderven at magion.nl>wrote:
>  Hi,
> Only one select control can be active at the same time. Selections are made
> in the layer that is on top of the Z-order.
> Kind regards,
> Jan
> *From:* users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
> *On Behalf Of *Adorian Ardelean
> *Sent:* Thursday, December 04, 2008 09:47
> *To:* users at openlayers.org
> *Subject:* [OpenLayers-Users] GeoJSON layer and modifyFeature control
> Hi,
> I have a very simple question: is it possible to modify features in a layer
> populated from a GeoJSON file? I am asking just about modifying feature on
> map without the saving part.
> I did add the modifyFeature control, but I cannot select and modify any of
> the polygons in this layer ( var regions = new
> OpenLayers.Layer.Vector("regions",{extractAttributes:true, format:
> OpenLayers.Format.GeoJSON, projection: new
> OpenLayers.Projection("EPSG:4326"), styleMap: new
> OpenLayers.StyleMap(mystyle)});)
> Another modifyFeature control works OK on a second vector layer (var
> vectors = new OpenLayers.Layer.Vector("vectors");).
> All the best,
> Adorian
> Dr. Adorian Ardelean
> coordinator of myNature Project
> http://mybiosis.info/nature/portal.php?pagename=firstpage [a Romanian
> biodiversity-database]
> http://mybiosis.info/nature/portal.php?pagename=adorian [CV]
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.176 / Virus Database: 270.9.12/1824 - Release Date: 2-12-2008
> 9:31
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081204/721891b2/attachment.html
