[OpenLayers-Users] GeoJSON layer and modifyFeature control
Jan van der Ven
j.vanderven at magion.nl
Thu Dec 4 06:25:20 EST 2008
Dear Adorian,
This is the code I have to activate a modifyFeature on a geojson layer. I
have a lot of those, so I activate it on a layer by name:
modifyControl = new
OpenLayers.Control.ModifyFeature(map.getLayersByName(stateNames[modifyContro
lIndex])[0]);
map.addControl(modifyControl);
modifyControl.activate();
Hope this helps.
Kind regards,
Jan
_____
From: Adorian Ardelean [mailto:mynature at gmail.com]
Sent: Thursday, December 04, 2008 10:17
To: j.vanderven at magion.nl
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] GeoJSON layer and modifyFeature control
Hi Jan,
In test case, it does not work even if I have only one layer and one
modifyFeature control (no other selectFeature and modifyFeature controls).
In real application case, I switch (one-at-a-time) among controls using an
external form and multiple selection controls work on the two distinct
layers (let say I have several selectFeature controls to get feature infos
in various layers). Only the modifyFeature on the GeoJSON layer does not
work.
All the best,
Adorian
On Thu, Dec 4, 2008 at 9:54 AM, Jan van der Ven <j.vanderven at magion.nl>
wrote:
Only one select control can be active at the same time. Selections are made
in the layer that is on top of the Z-order.
Kind regards,
Jan
_____
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
Behalf Of Adorian Ardelean
Sent: Thursday, December 04, 2008 09:47
To: users at openlayers.org
Subject: [OpenLayers-Users] GeoJSON layer and modifyFeature control
I have a very simple question: is it possible to modify features in a layer
populated from a GeoJSON file? I am asking just about modifying feature on
map without the saving part.
I did add the modifyFeature control, but I cannot select and modify any of
the polygons in this layer ( var regions = new
OpenLayers.Layer.Vector("regions",{extractAttributes:true, format:
OpenLayers.Format.GeoJSON, projection: new
OpenLayers.Projection("EPSG:4326"), styleMap: new
OpenLayers.StyleMap(mystyle)});)
Another modifyFeature control works OK on a second vector layer (var vectors
= new OpenLayers.Layer.Vector("vectors");).
All the best,
Adorian
Dr. Adorian Ardelean
coordinator of myNature Project
http://mybiosis.info/nature/portal.php?pagename=firstpage [a Romanian
biodiversity-database]
http://mybiosis.info/nature/portal.php?pagename=adorian [CV]
No virus found in this incoming message.
Checked by AVG - http://www.avg.com
Version: 8.0.176 / Virus Database: 270.9.12/1824 - Release Date: 2-12-2008
9:31
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
9:31
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081204/46e624be/attachment.html
