[OpenLayers-Users] GeoJSON layer and modifyFeature control
Adorian Ardelean
mynature at gmail.com
Thu Dec 4 07:41:36 EST 2008
Dear Jan,
I have tried to declare the control also as in your example. It did not work
either.
In the meantime, I have localized the problem although I do not have a
solution to it yet.
Turns out that if I remove style declaration the modify tool works.
With this the modifyFeature does not work:
var regions = new OpenLayers.Layer.Vector("regions",{extractAttributes:true,
format: OpenLayers.Format.GeoJSON, projection: new
OpenLayers.Projection("EPSG:4326"), styleMap: new
OpenLayers.StyleMap(mystyle)});
With this it works
OpenLayers.Projection("EPSG:4326")});
However, the style is quite necessary because depending on properties
(attributes) I store in GeoJSON array, I have rules to change style of
features when rendered. It seems that this interferes somehow with the
select style of modifyFeature controlo. Or...
Hopefully, I will find a solution to keep them both. Otherwise, is there a
way to migrate features from one vector layer to another?
All the best,
Adorian
On Thu, Dec 4, 2008 at 12:25 PM, Jan van der Ven <j.vanderven at magion.nl>wrote:
> Dear Adorian,
> This is the code I have to activate a modifyFeature on a geojson layer. I
> have a lot of those, so I activate it on a layer by name:
> modifyControl = new
> OpenLayers.Control.ModifyFeature(map.getLayersByName(stateNames[modifyControlIndex])[0]);
> map.addControl(modifyControl);
> modifyControl.activate();
> Hope this helps.
> Kind regards,
> Jan
> *From:* Adorian Ardelean [mailto:mynature at gmail.com]
> *Sent:* Thursday, December 04, 2008 10:17
> *To:* j.vanderven at magion.nl
> *Cc:* users at openlayers.org
> *Subject:* Re: [OpenLayers-Users] GeoJSON layer and modifyFeature control
> Hi Jan,
> In test case, it does not work even if I have only one layer and one
> modifyFeature control (no other selectFeature and modifyFeature controls).
> In real application case, I switch (one-at-a-time) among controls using an
> external form and multiple selection controls work on the two distinct
> layers (let say I have several selectFeature controls to get feature infos
> in various layers). Only the modifyFeature on the GeoJSON layer does not
> work.
> All the best,
> Adorian
> On Thu, Dec 4, 2008 at 9:54 AM, Jan van der Ven <j.vanderven at magion.nl>wrote:
>> Hi,
>> Only one select control can be active at the same time. Selections are
>> made in the layer that is on top of the Z-order.
>> Kind regards,
>> Jan
>> *From:* users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
>> *On Behalf Of *Adorian Ardelean
>> *Sent:* Thursday, December 04, 2008 09:47
>> *To:* users at openlayers.org
>> *Subject:* [OpenLayers-Users] GeoJSON layer and modifyFeature control
>> Hi,
>> I have a very simple question: is it possible to modify features in a
>> layer populated from a GeoJSON file? I am asking just about modifying
>> feature on map without the saving part.
>> I did add the modifyFeature control, but I cannot select and modify any of
>> the polygons in this layer ( var regions = new
>> OpenLayers.Layer.Vector("regions",{extractAttributes:true, format:
>> OpenLayers.StyleMap(mystyle)});)
>> Another modifyFeature control works OK on a second vector layer (var
>> vectors = new OpenLayers.Layer.Vector("vectors");).
>> All the best,
>> Adorian
>> Dr. Adorian Ardelean
>> coordinator of myNature Project
>> http://mybiosis.info/nature/portal.php?pagename=firstpage [a Romanian
>> biodiversity-database]
>> http://mybiosis.info/nature/portal.php?pagename=adorian [CV]
>> No virus found in this incoming message.
>> Checked by AVG - http://www.avg.com
>> Version: 8.0.176 / Virus Database: 270.9.12/1824 - Release Date: 2-12-2008
>> 9:31
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> 9:31
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081204/cd77abaf/attachment.html
