[OpenLayers-Users] DrawFeature with callback?
Nino Saturnino Martinez Vazquez Wael nino.martinez at jayway.dk
Mon Dec 8 06:50:53 EST 2008
Hi again
What if you want todo the exact same thing with the editing toolbar?
            map.addControl(new
OpenLayers.Control.EditingToolbar(vectors,OpenLayers.Handler.Polygon,{'featureAdded':
serialize}));
Does not work...
Adorian Ardelean wrote:
> Hi Nino,
> This works ok for me:
> dosomething = function (feature)
>       //do something with polygon
>       alert("yeeehaaa");
> controls = {
>   polygon: new
> OpenLayers.Control.DrawFeature(regions,OpenLayers.Handler.Polygon,
> {'featureAdded': dosomething})
> All the best,
> Adorian
> On Fri, Dec 5, 2008 at 2:03 PM, Nino Saturnino Martinez Vazquez Wael
> <nino.martinez at jayway.dk <mailto:nino.martinez at jayway.dk>> wrote:
>     Okay so I now have this, still not working though:
>     <html xmlns="http://www.w3.org/1999/xhtml">
>      <head>
>       <title>OpenLayers Regular Polygon Example</title>
>       <script src="http://openlayers.org/api/OpenLayers.js"></script>
>       <script type="text/javascript">
>           var map, polygonControl;
>           OpenLayers.Util.onImageLoadErrorColor = "transparent";
>           function init(){
>               map = new OpenLayers.Map('map');
>                         var wmsLayer = new OpenLayers.Layer.WMS(
>     "OpenLayers WMS",
>                   "http://labs.metacarta.com/wms/vmap0?", {layers:
>     'basic'});
>               var polygonLayer = new OpenLayers.Layer.Vector("Polygon
>     Layer");
>               map.addLayers([wmsLayer, polygonLayer]);
>               map.addControl(new OpenLayers.Control.LayerSwitcher());
>               map.addControl(new OpenLayers.Control.MousePosition());
>               dosomething = function (polygon)
>                   alert("yeeehaaa");
>               polyOptions = {sides: 4, callbacks: {'featureAdded':
>     dosomething}  };
>               polygonControl = new
>     OpenLayers.Control.DrawFeature(polygonLayer,
>     OpenLayers.Handler.RegularPolygon,
>                                               {handlerOptions: polyOptions
>                         map.addControl(polygonControl);
>                         map.setCenter(new OpenLayers.LonLat(0, 0), 3);
>                         document.getElementById('noneToggle').checked
>     = true;
>           function setOptions(options) {
>               polygonControl.handler.setOptions(options);
>           function setSize(fraction) {
>               var radius = fraction * map.getExtent().getHeight();
>               polygonControl.handler.setOptions({radius: radius,
>                                                  angle: 0});
>       </script>
>      </head>
>      <body onload="init()">
>       <h2 id="title">OpenLayers Regular Polygon Example</h2>
>       <p id="shortdesc">
>         Shows how to use the RegularPolygon handler to draw features with
>         different numbers of sides.
>       </p>
>       <div id="map" class="smallmap"></div>
>       <div id="config">
>                 <ul id="controls"><b>Map Controls</b>
>               <li>
>                   <input type="radio" name="type"
>                          value="none" id="noneToggle"
>                          onclick="polygonControl.deactivate()"
>                          checked="checked" />
>                   <label for="noneToggle">navigate</label>
>               </li>
>               <li>
>                          value="polygon" id="polygonToggle"
>                          onclick="polygonControl.activate()" />
>                   <label for="polygonToggle">draw polygon</label>
>               </li>
>           </ul>
>       </div>
>      </body>
>     </html>
>         Hi,
>         I presume you have to specify the event name somehow. Try
>         including this:
>          ...callbacks: {'featureAdded': dosomething}...
>         All the best,
>         Adorian
>         On Fri, Dec 5, 2008 at 12:59 PM, Nino Saturnino Martinez
>         Vazquez Wael <nino.martinez at jayway.dk
>         <mailto:nino.martinez at jayway.dk>>> wrote:
>            Hi Guys
>            Im doing a integration for the Apache Wicket framework(
>          http://wicketstuff.org/confluence/display/STUFFWIKI/wicket-contrib-openlayers
>            ), and want to add some more features. Im looking into
>         adding the
>            possibility to draw polygons, however I cant find a example
>         where
>            theres
>            a simple callback involved once the polygon are drawn,
>         however the api
>            mentions it's possible.
>            As you can see from the below code the only thing I need
>         for this
>            little
>            thing to work are the function that calls the alert to be
>         picked up.
>            Please say if you want me to elaborate further.
>             <head>
>               <script
>                   function init(){
>         "OpenLayers WMS",
>            'basic'});
>            Layer");
>                       map.addControl(new
>                       map.addControl(new
>            {function(value){alert('yeeeha');}}  };
>                                                       {handlerOptions:
>            polyOptions
>                       document.getElementById('noneToggle').checked =
>         true;
>          document.getElementById('irregularToggle').checked =
>            false;
>                                                          angle: 0});
>               </script>
>             </head>
>               <p id="shortdesc">
>         features with
>               </p>
>               <div id="config">
>                       <li>
>                       </li>
>                       <li>
>                       </li>
>                   </ul>
>               </div>
>             </body>
>            </html>
>            -Nino
>            _______________________________________________
>            Users mailing list
>            Users at openlayers.org <mailto:Users at openlayers.org>
>         <mailto:Users at openlayers.org <mailto:Users at openlayers.org>>
>            http://openlayers.org/mailman/listinfo/users
>         Dr. Adorian Ardelean
>         coordinator of myNature Project
>         http://mybiosis.info/nature/portal.php?pagename=firstpage [a
>         Romanian biodiversity-database]
>         http://mybiosis.info/nature/portal.php?pagename=adorian [CV]
>     -Wicket for love
>     Nino Martinez Wael
>     Java Specialist @ Jayway DK
>     http://www.jayway.dk
>     +45 2936 7684
> http://mybiosis.info/nature/portal.php?pagename=firstpage [a Romanian
-Wicket for love
Nino Martinez Wael
+45 2936 7684
