[OpenLayers-Users] DrawFeature with callback?
Nino Saturnino Martinez Vazquez Wael nino.martinez at jayway.dk
Tue Dec 9 02:41:49 EST 2008
Thanks it worked as well :)
Eric Lemoine wrote:
> Hi
> var e = new OpenLayers.Control.EditingToolbar(...);
> for(var i = 0; i<e.controls.length; i++) {
>     var c = e.controls[i];
>     c.events.on({
>        "featureadded": functio(e) {
>            alert(e.feature);
> Untested.
> Cheers,
> Eric
> 2008/12/8, Nino Saturnino Martinez Vazquez Wael <nino.martinez at jayway.dk>:
>> Hi again
>> What if you want todo the exact same thing with the editing toolbar?
>>             map.addControl(new
>> OpenLayers.Control.EditingToolbar(vectors,OpenLayers.Handler.Polygon,{'featureAdded':
>> serialize}));
>> Does not work...
>> Adorian Ardelean wrote:
>>> Hi Nino,
>>> This works ok for me:
>>> dosomething = function (feature)
>>>       //do something with polygon
>>>       alert("yeeehaaa");
>>> controls = {
>>>   polygon: new
>>> OpenLayers.Control.DrawFeature(regions,OpenLayers.Handler.Polygon,
>>> {'featureAdded': dosomething})
>>> All the best,
>>> Adorian
>>> On Fri, Dec 5, 2008 at 2:03 PM, Nino Saturnino Martinez Vazquez Wael
>>> <nino.martinez at jayway.dk <mailto:nino.martinez at jayway.dk>> wrote:
>>>     Okay so I now have this, still not working though:
>>>     <html xmlns="http://www.w3.org/1999/xhtml">
>>>      <head>
>>>       <title>OpenLayers Regular Polygon Example</title>
>>>       <script src="http://openlayers.org/api/OpenLayers.js"></script>
>>>       <script type="text/javascript">
>>>           var map, polygonControl;
>>>           OpenLayers.Util.onImageLoadErrorColor = "transparent";
>>>           function init(){
>>>               map = new OpenLayers.Map('map');
>>>                         var wmsLayer = new OpenLayers.Layer.WMS(
>>>     "OpenLayers WMS",
>>>                   "http://labs.metacarta.com/wms/vmap0?", {layers:
>>>     'basic'});
>>>               var polygonLayer = new OpenLayers.Layer.Vector("Polygon
>>>     Layer");
>>>               map.addLayers([wmsLayer, polygonLayer]);
>>>               map.addControl(new OpenLayers.Control.LayerSwitcher());
>>>               map.addControl(new OpenLayers.Control.MousePosition());
>>>               dosomething = function (polygon)
>>>                   alert("yeeehaaa");
>>>               polyOptions = {sides: 4, callbacks: {'featureAdded':
>>>     dosomething}  };
>>>               polygonControl = new
>>>     OpenLayers.Control.DrawFeature(polygonLayer,
>>>     OpenLayers.Handler.RegularPolygon,
>>>                                               {handlerOptions: polyOptions
>>>                         map.addControl(polygonControl);
>>>                         map.setCenter(new OpenLayers.LonLat(0, 0), 3);
>>>                         document.getElementById('noneToggle').checked
>>>     = true;
>>>           function setOptions(options) {
>>>               polygonControl.handler.setOptions(options);
>>>           function setSize(fraction) {
>>>               var radius = fraction * map.getExtent().getHeight();
>>>               polygonControl.handler.setOptions({radius: radius,
>>>                                                  angle: 0});
>>>       </script>
>>>      </head>
>>>      <body onload="init()">
>>>       <h2 id="title">OpenLayers Regular Polygon Example</h2>
>>>       <p id="shortdesc">
>>>         Shows how to use the RegularPolygon handler to draw features with
>>>         different numbers of sides.
>>>       </p>
>>>       <div id="map" class="smallmap"></div>
>>>       <div id="config">
>>>                 <ul id="controls"><b>Map Controls</b>
>>>               <li>
>>>                   <input type="radio" name="type"
>>>                          value="none" id="noneToggle"
>>>                          onclick="polygonControl.deactivate()"
>>>                          checked="checked" />
>>>                   <label for="noneToggle">navigate</label>
>>>               </li>
>>>               <li>
>>>                          value="polygon" id="polygonToggle"
>>>                          onclick="polygonControl.activate()" />
>>>                   <label for="polygonToggle">draw polygon</label>
>>>               </li>
>>>           </ul>
>>>       </div>
>>>      </body>
>>>     </html>
>>>         Hi,
>>>         I presume you have to specify the event name somehow. Try
>>>         including this:
>>>          ...callbacks: {'featureAdded': dosomething}...
>>>         All the best,
>>>         Adorian
>>>         On Fri, Dec 5, 2008 at 12:59 PM, Nino Saturnino Martinez
>>>         <mailto:nino.martinez at jayway.dk>>> wrote:
>>>            Hi Guys
>>>            Im doing a integration for the Apache Wicket framework(
>>> http://wicketstuff.org/confluence/display/STUFFWIKI/wicket-contrib-openlayers
>>>            ), and want to add some more features. Im looking into
>>>         adding the
>>>            possibility to draw polygons, however I cant find a example
>>>         where
>>>            theres
>>>            a simple callback involved once the polygon are drawn,
>>>         however the api
>>>            mentions it's possible.
>>>            As you can see from the below code the only thing I need
>>>         for this
>>>            little
>>>            thing to work are the function that calls the alert to be
>>>         picked up.
>>>            Please say if you want me to elaborate further.
>>>             <head>
>>>               <script
>>>                   function init(){
>>>         "OpenLayers WMS",
>>>            'basic'});
>>>            Layer");
>>>                       map.addControl(new
>>>                       map.addControl(new
>>>            {function(value){alert('yeeeha');}}  };
>>>                                                       {handlerOptions:
>>>            polyOptions
>>>                       document.getElementById('noneToggle').checked =
>>>         true;
>>>          document.getElementById('irregularToggle').checked =
>>>            false;
>>>                                                          angle: 0});
>>>               </script>
>>>             </head>
>>>               <p id="shortdesc">
>>>         features with
>>>               </p>
>>>               <div id="config">
>>>                       <li>
>>>                       </li>
>>>                       <li>
>>>                       </li>
>>>                   </ul>
>>>               </div>
>>>             </body>
>>>            </html>
>>>            -Nino
>>>            _______________________________________________
>>>            Users mailing list
>>>            Users at openlayers.org <mailto:Users at openlayers.org>
>>>         <mailto:Users at openlayers.org <mailto:Users at openlayers.org>>
>>>            http://openlayers.org/mailman/listinfo/users
>>>         Dr. Adorian Ardelean
>>>         coordinator of myNature Project
>>>         http://mybiosis.info/nature/portal.php?pagename=firstpage [a
>>>         Romanian biodiversity-database]
>>>         http://mybiosis.info/nature/portal.php?pagename=adorian [CV]
>>>     -Wicket for love
>>>     Nino Martinez Wael
>>>     Java Specialist @ Jayway DK
>>>     http://www.jayway.dk
>>>     +45 2936 7684
>>> http://mybiosis.info/nature/portal.php?pagename=firstpage [a Romanian
>> -Wicket for love
>> Nino Martinez Wael
>> +45 2936 7684
>> Users mailing list
-Wicket for love
Nino Martinez Wael
+45 2936 7684
