[OpenLayers-Users] HTTP protocol with featureserver
Alexandre Dube
adube at mapgears.com
Wed Dec 10 15:59:49 EST 2008
Andreas Hocevar wrote:
> Yes, but quite some efforts would be required. Reading the insertIds
> this is the format's job. Format.GeoJSON does not know about insertIds.
> The best thing to do here would be to subclass Format.GeoJSON and create
> e.g. a Format.GeoJSON.FeatureServer. The next thing is that you need a
> protocol that can handle insertIds. Protocol.HTTP cannot do that, so
> this would also have to be extended.
> I am also quite new to the vector behavior stuff, so I might be wrong.
> But to me it seems that the above should work.
> Let me know when you need more help, because I have to gain deeper
> insight into that code anyway and doing it for a purpose other than just
> looking at it will also make it easier for me.
> Regards,
> Andreas.
Yep, that's exactly what I had in mind.
Eric suggested to use the protocol.commit() function, but it has the
same problem ( no fid on new added features ), so I'll have to implement
one. I'm still trying to figure how to just add function on commit(),
there's already something for that but I'm missing something because
when I set one, it replaces what is usually does instead of adding one :
olWFSRoads = new OpenLayers.Layer.Vector("Roads FS GeoJSON", {
scales: oMap.getScales(8,10),
styleMap: oStyleMap,
strategies: [new OpenLayers.Strategy.BBOX()/*, oSaveStrategy*/],
protocol: new OpenLayers.Protocol.HTTP({
url: szFSURL+"/bdga_route_l_arc?format=GeoJSON",
format: new OpenLayers.Format.GeoJSON(),
create: function(){alert("foo")} //<-- this gets
triggered, but no POST is created...
I'll continue to look deeper and try to understand this.
Thanks,
Alexandre Dubé
Mapgears
www.mapgears.com
