[OpenLayers-Users] Problem in displaying GML layer
S.Reena
reena at indiamail.com
Fri Dec 12 04:29:22 EST 2008
Hey Frank,
I checked everything ...with ur code now even map is not getting displayed .
I am attaching my gpx file with this mail.
http://www.nabble.com/file/p20971591/TeamBday1.gpx TeamBday1.gpx
Thanks,
Reena.
Frank Broniewski-5 wrote:
> On Tuesday 09 December 2008 11:36:54 S.Reena wrote:
>> Hi All,
>> I want to upload gpx file on my map but its giving error that it cannot
>> be
>> displayed. I am attaching my gpx file with this
>> map.addLayer(new OpenLayers.Layer.GML("GPX", "gpx/mygps.gpx",
>> format: OpenLayers.Format.GPX,
>> formatOptions:{ extractWaypoints:true,
>> extractTracks:true,
>> extractRoutes:true,
>> extractAttributes:true
>> http://www.nabble.com/file/p20912231/mygps.gpx mygps.gpx
>> Thanks in advance :)
>> Cheers,
>> Reena.
> Hi Reena,
> I can't see anything wrong with your layer definitions, I am basically
> using
> the same. Did you check your permissions on the gpx file (read)? Is the
> path
> correct? Did you check if your gpx file is valid?
> I am using the definition below, maybe it helps you.
> Frank
> pt = new OpenLayers.Layer.GML (
> "Informationen",
> "http://clydeswelt.frabron.de/kml/wpt.gpx",
> projection: new OpenLayers.Projection("EPSG:4326"),
> styleMap: ptStyle,
> formatOptions: {
> extractWaypoints: true,
> extractTracks: false,
> extractRoutes: false,
> extractAttributes: true
> Frank Broniewski
> Metrico s.àr.l. ( http://www.metrico.lu )
> 36, rue des Romains
> L-5433 Niederdonven
> Luxembourg
> Fon: +352 26 74 94 28
> Fax: +352 26 74 94 99
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/Problem-in-displaying-GML-layer-tp20912231p20971591.html
