[OpenLayers-Users] FW: Edit circles not showing when styleMap
isspecified
Jan van der Ven
j.vanderven at magion.nl
Tue Dec 16 12:40:25 EST 2008
Dear all,
With your help, I think it is fixed.
The trick was to use OpenLayers.Util.applyDefaults in the named hash, for
both "default" and "select".
The code now reads:
for(i=0; i<9; i++)
var styleMap = new
OpenLayers.StyleMap({"default":OpenLayers.Util.applyDefaults({fillColor:
stateColors[i], fillOpacity: 0.4, strokeColor: stateColors[i],
strokeWidth:2},OpenLayers.Feature.Vector.style["default"]),"select":
OpenLayers.Util.applyDefaults({},
OpenLayers.Feature.Vector.style["select"])});
var laag = new OpenLayers.Layer.GML(stateNames[i], url + stateNames[i]
+ ".geojson", {format:OpenLayers.Format.GeoJSON, projection: new
OpenLayers.Projection("EPSG:28993"), resolutions:ress, visibility:false,
styleMap:styleMap});
laag.events.on({"featuremodified": onFeatureModified});
map.addLayer(laag);
selectControls[i]=new OpenLayers.Control.SelectFeature(laag,{onSelect:
onFeatureSelect, onUnselect:onFeatureUnselect, toggleKey:"ctrlKey",
multipleKey:"shiftKey", hover:false, toggle:false, clickout:false,
multiple:true, box:false});
map.addControl(selectControls[i]);
This gives me 9 layers all, coloured differently. When a feature is
selected, the feature turns blue (OpenLayers default). When browsing with
Chrome, you can even select features that are not in the top layer.
If the user switches to edit mode, a ModifyFeature control is created and
activated:
modifyControl = new OpenLayers.Control.ModifyFeature(
map.getLayersByName(stateNames[top])[0], {mode:
OpenLayers.Control.ModifyFeature.RESHAPE});
map.addControl(modifyControl);
modifyControl.activate();
And this works for the top layer (as it was programmed to do), while in
Chrome you can still select from the layers below the editable layer.
Thanks for all the help.
Kind regards,
Jan
-----Original Message-----
From: arnd.wippermann at web.de [mailto:arnd.wippermann at web.de]
Sent: Monday, December 15, 2008 18:23
To: j.vanderven at magion.nl
Cc: users at openlayers.org
Subject: AW: [OpenLayers-Users] Edit circles not showing when styleMap
isspecified
There is a property virtualStyle for the ModifyFeature Control. Perhaps this
has to set.
I do this before I add the controls:
OpenLayers.Feature.Vector.style['select']['fillColor'] = 'yellow';
OpenLayers.Feature.Vector.style['select']['strokeColor'] = 'yellow';
var selectStyle = OpenLayers.Util.extend({},
OpenLayers.Feature.Vector.style['select']);
ctrlSelectFeature.selectStyle = selectStyle;
ctrlModifyFeature.virtualStyle = selectStyle;
Arnd Wippermann
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Jan van der Ven
Gesendet: Montag, 15. Dezember 2008 15:23
An: users at openlayers.org
Betreff: Re: [OpenLayers-Users] Edit circles not showing when styleMap
isspecified
Dear Alexandre,
Thanks for the quick reply.
I tried it out right away, and modified the code as shown below:
function addGeoJSONLayers()
for(i=0; i<nLayers; i++)
mystyles = new OpenLayers.StyleMap(
"default": new OpenLayers.Style({
myrules = new OpenLayers.Rule({symbolizer:{fillColor:stateColors[i],
strokeColor:stateColors[i], strokeWidth:2, fillOpacity:0.4},
elseFilter:true});
mystyles.styles["default"].addRules(myrules);
var laag = new OpenLayers.Layer.GML(stateNames[i], biskurl +
"html/kml/" + stateNames[i] + ".geojson", {format:OpenLayers.Format.GeoJSON,
projection: new OpenLayers.Projection("EPSG:28993"), resolutions:ress,
visibility:false, styleMap:mystyles }); [...]
Unfortunately, the behavior still is that the handles do not appear.
Kind regards,
Jan
From: Alexandre Dube [mailto:adube at mapgears.com]
Sent: Monday, December 15, 2008 14:56
Subject: Re: [OpenLayers-Users] Edit circles not showing when styleMap is
specified
Hi Jan,
I also had this problem and resolved it by adding theses lines :
rules = [new OpenLayers.Rule({
symbolizer: {strokeColor:"red",strokeWidth: 2},
elseFilter: true
styles.styles["default"].addRules(rules);
Hope this helps,
Alexandre
Jan van der Ven wrote:
> Dear list,
> I have a map to which I add nine vector layers (all polygons). The
> layers all should have their own color for rendering the features. I
> have too many features to put them all in one layer, and use an
> attribute
to style them.
> The code I have for this is as follows:
> * Add the GeoJSON Layers
> var styles = new OpenLayers.StyleMap({
> strokeWidth:2,
> fillOpacity:0.4
> visibility:false, styleMap:styles});
> map.addLayer(laag);
> // These are the ones the user may work with
> I know only the topmost layer has an 'active' selectControl.
> There is a button that the user can click to go from "select" mode to
"edit"
> mode. This essentially turns off all selectControls and creates and
> activates a ModifyFeature control for the top layer:
> modifyControl = new
> OpenLayers.Control.ModifyFeature(map.getLayersByName(stateNames[top])[
> 0], {mode:OpenLayers.Control.ModifyFeature.RESHAPE});
> The problem is that if the styleMap entry is present when creating the
> layer, the edit handles (the circles) do not become visible and the
> mouse cursor does not changes when moving to the corners of the
> polygon. But, if I comment out the styleMap, like so:
> visibility:false /*, styleMap:styles*/});
> It works as expected.
> My questions are:
> 1) Is this the right way to set the color for a layer?
> 2) If so, why would that influence the ModifyFeature control?
> 3) What can I do to fix this?
> Thanks in advance.
> Kind regards,
> Jan van der Ven
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
No virus found in this incoming message.
Checked by AVG - http://www.avg.com
Version: 8.0.176 / Virus Database: 270.9.16/1842 - Release Date: 14-12-2008
12:28
Users mailing list
Version: 8.0.176 / Virus Database: 270.9.18/1848 - Release Date: 14-12-2008
12:28
