[OpenLayers-Users] Several control for several layers at the
same time
Eric Lemoine
eric.c2c at gmail.com
Sat Dec 20 04:07:12 EST 2008
Hi
This is currently unsupported by OpenLayers.
Eric
2008/12/17, arno974 <arnaud.sig at gmail.com>:
> Hi,
> I'm using OL 2.7 and i wondering if it's possible to have several control
> for several layers at the same time. For example, in my project i'm using
> the Select Control for several layers but i can only select on layer.
> I saw in this post
> (http://www.nabble.com/Several-selectFeature-control-td20151130.html#a20153141)
> that there is a limitation for the control. Only one can be activate at the
> same time. Is they're a way or a patch to fix this limitation?
> The solution proposed by Eric Lemoine was to regroup all the layers in a
> same layer. But due to the way of my project is organize i can't do it in
> this way.
> Thanks in advance.
> Best regards
> Arnaud
> http://www.nabble.com/Several-control-for-several-layers-at-the-same-time-tp21052904p21052904.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
