[OpenLayers-Users] boundaries of lineString
Tim Schaub tschaub at openplans.org
Tue Feb 12 10:52:21 EST 2008
Hey-
Rupesh M G wrote:
>         Thank you for the reply. But I think it is not correct.
> For example, if I draw the linestring with 4 points, I'm able to see a
> polygon with 8 vertices.
A linestring geometry with 4 points has 4 points.  When you see it
rendered, it looks like a polygon to you, but the geometry is just a
linestring.
It sounds like you're talking about buffering a geometry.  When you
buffer a linestring geometry, you get a polygon geometry.
Tim
> But if I print the components.length of the linestring, it just says 4.
> I tried it with the example in the url
> http://openlayers.org/dev/examples/vector-features.html
> Regards,
> Rupesh
> *"Pierre GIRAUD" <bluecarto at gmail.com>*
> 02/11/2008 03:58 PM
> To
> 	"Rupesh M G" <RupeshM at ibsplc.com>
> cc
> 	users at openlayers.org
> Subject
> 	Re: [OpenLayers-Users] boundaries of lineString
> It should be quite easy because geometry like lineString and Polygon
> are composite geometries.
> For example, a OpenLayers.LineString has a 'components' property which
> is an array of OpenLayers.Points.
> That way, you can get all the vertices using a loop like following :
> for(var i=0; i <= thelinestring.components.length; i++) {
>    // do something with thelinestring.components[i] which is an OL point
> Regards,
> Pierre
> On Feb 11, 2008 9:02 AM, Rupesh M G <RupeshM at ibsplc.com> wrote:
>  > Hi,
>  >         I'm working on an application about roads. There I need to mark a
>  > part of the road, and execute some query.
>  > My user will click a set of points to form a sequence of lines passing
>  > through the center of the road, because there can be bends in the road.
>  > I plan to draw a lineString going through these points. Using a bigger
>  > strokeWidth, I can show it like a road (or like a filled polygon).
>  > Is there any way to get the vertices of that polygon?
>  > Thanks & Regards,
>  > Rupesh
>  >  DISCLAIMER:
>  >  "The information in this e-mail and any attachment is intended only
> for the
>  > person to whom it is addressed and may contain confidential and/or
>  > privileged material. If you have received this e-mail in error, kindly
>  > contact the sender and destroy all copies of the original
> communication. IBS
>  > makes no warranty, express or implied, nor guarantees the accuracy,
> adequacy
>  > or completeness of the information contained in this email or any
>  > and is not liable for any errors, defects, omissions, viruses or for
>  > resultant loss or damage, if any, direct or indirect."
>  > _______________________________________________
>  > Users mailing list
>  > Users at openlayers.org
>  > http://openlayers.org/mailman/listinfo/users
> _
> DISCLAIMER:__ _
> "The information in this e-mail and any attachment is intended only for
> the person to whom it is addressed and may contain confidential and/or
> contact the sender and destroy all copies of the original communication.
> IBS makes no warranty, express or implied, nor guarantees the accuracy,
> adequacy or completeness of the information contained in this email or
> any attachment and is not liable for any errors, defects, omissions,
> viruses or for resultant loss or damage, if any, direct or indirect."
> !DSPAM:4033,47b02979256741431913854!
> Users mailing list
