[OpenLayers-Users] Edit a "freehand polygon"
Swärd Mårten
marten.sward at smhi.se
Mon Feb 11 06:23:19 EST 2008
Hello!
I need some functionality that makes it possible to edit the points in a freehand drawn polygon. I know that it's tecnicaly possible to do this but in real life the edit function, as I know it, is very time counsuming to use due to the many points that has to be modified. The two questions that I have are as follows:
A) Is it possible to change the edit function so that when you edit one point the naigbor points follows.. And so to say smoothen the curve of the edited point relative to the rest of the points..
B) If the answer is a big NO on A. =) Is it possible to reduce the number of points that is drawn when using the freehand mode?
B II) Or is it possible to reduce the number of points on a polygon after you have drawn it?
Best regards: Mårten
Mvh:
Mårten Swärd
Systemutvecklare/Webbutvecklare, ITs
SMHI, Sveriges Meteorologiska och Hydrologiska Institut
Tel: +46 11 495 8469
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080211/2c6e64f2/attachment.html
