[OpenLayers-Users] Is there an example of using layers with differing source projections.. ie using Proj4?
Lance Dyas lancelot at inetnebr.com
Wed Feb 13 22:09:15 EST 2008
The example usage I am thinking of is where I have a WFS layer of one
projection and mayhaps a WMS of another.. WFS 1.0 seem inclined to
answer in whatever projection they have... I think it is in 1.1 that you
are better able to specify you want the layer in a specific
projection..and actually get it in that projection.
Mike Adair wrote:
> An example that doesn't do much but demonstrates how to include
> Proj4js and use the OpenLayers objects to do coordinate transformations:
> <script src="../lib/OpenLayers.js" type="text/javascript"></script>
> <script src="../lib/proj4js/proj4js-compressed.js"
> <script type="text/javascript">
> Proj4js.defs["EPSG:3003"] = "+title=Gauss Boaga EPSG:3003 +proj=tmerc
> +lat_0=0 +lon_0=9 +k=0.999600 +x_0=1500000 +y_0=0 +ellps=intl
> +units=m  +no_defs";
>  function init() {
>    var point = new OpenLayers.Geometry.Point(9.5, 30.0);
>    var src = new OpenLayers.Projection('EPSG:4326');
>    var dest = new OpenLayers.Projection('EPSG:3003');
>    OpenLayers.Projection.transform(point, src, dest);
>    alert('coordinates transformed:'+point.toString());
>  window.onload = init;
> </script>
> The point to be transformed is any object that has  .x and  .y
> properties.
> Mike
> Lance Dyas wrote:
>> Mike Adair wrote:
>>> EPSG:3003 uses a tmerc projection and is supported by Proj4js.  Did
>>> you remember to include the Proj4js library with a script tag in
>>> your application?
>>> Mike
