[OpenLayers-Users] Is there an example of using layers with
differing source projections.. ie using Proj4?
Mike Adair
madair at dmsolutions.ca
Wed Feb 13 09:59:53 EST 2008
An example that doesn't do much but demonstrates how to include Proj4js
and use the OpenLayers objects to do coordinate transformations:
<script src="../lib/OpenLayers.js" type="text/javascript"></script>
<script src="../lib/proj4js/proj4js-compressed.js"
<script type="text/javascript">
Proj4js.defs["EPSG:3003"] = "+title=Gauss Boaga EPSG:3003 +proj=tmerc
+lat_0=0 +lon_0=9 +k=0.999600 +x_0=1500000 +y_0=0 +ellps=intl +units=m
+no_defs";
function init() {
var point = new OpenLayers.Geometry.Point(9.5, 30.0);
var src = new OpenLayers.Projection('EPSG:4326');
var dest = new OpenLayers.Projection('EPSG:3003');
OpenLayers.Projection.transform(point, src, dest);
alert('coordinates transformed:'+point.toString());
window.onload = init;
</script>
The point to be transformed is any object that has .x and .y properties.
Mike
Lance Dyas wrote:
> Mike Adair wrote:
>> EPSG:3003 uses a tmerc projection and is supported by Proj4js. Did you
>> remember to include the Proj4js library with a script tag in your
>> application?
>> Mike
