[OpenLayers-Users] Coordinates systems transformations?
Mike Adair madair at dmsolutions.ca
Thu Feb 14 09:24:39 EST 2008
EPSG:23030 is a UTM projection, so yes it is supported.
Mike
David E. Reksten wrote:
> Take a look at:
> http://spatialreference.org/ref/epsg/23030/
> http://spatialreference.org/ref/epsg/23030/proj4js/
> .david
> On 13/02/2008, Ruben Pardo <correosig at gmail.com> wrote:
>> hi,
>> does proj4js support EPSG:23030 to WGS84 transformation or viceversa?
>> i didn't see in the proj4js docs, is it going to support  it?
>> Thanks very much.
>> best regards
>> 2008/2/13, David E. Reksten <der at dod.no>:
>>> This is how I reproject LL to UTM32:
>>>     var destProj = new Proj4js.Proj(map.getProjection()); // Euref89 UTM32
>>>     var sourceProj = new Proj4js.Proj("EPSG:4326"); // WGS84 LonLat
>>>     var position = new OpenLayers.Geometry.Point(lon, lat);
>>>     Proj4js.transform(sourceProj, destProj, position);
>>> Thereafter, position.x and position.y will contain the reprojected
>> coordinates.
>>> Using trunk versions of OL and Proj4js. Hope this helps.
>>> .david
>>> On 13/02/2008, Andrea Maschio <andrea.maschio at gmail.com> wrote:
>>>> Hi all, I suppose that the method Bounds.transform(ProjA, ProjB)
>>>> should transform the coordinates between differents EPSG codes.
>>>> Now I was trying this:
>>>>             var p = bounds
>>>>              console.log(p)
>>>>              p = bounds.transform(new OpenLayers.Projection("EPSG:
>>>> 900913"), new OpenLayers.Projection("EPSG:3003"))
>>>>              console.log(p)
>>>> But p has always the same coords. Btw I am working in a projected
>>>> layer (projected from 3003 to 900913) and my wfs layers are ok, but
>>>> being my coords in the Gauss Boaga metric system, I cannot get them
>>>> correctly trying for example a GetFeatureInfo call using a BBOX.
>>>> Shall I perform a linear translation of the coordinates?
>>>> Thanks
>>>> Andrea Maschio
>>>> http://www.superandrew.it
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>>> Users mailing list
> Users mailing list
