[OpenLayers-Users] Using Aerial photos
MilesTogoe miles.togoe at gmail.com
Mon Feb 18 19:19:09 EST 2008
I want to use an aerial photo as the base map - I have lat/long
coordinates for the map corners.  What is the best way to use this if I
don't know the projection (since it is only 10 square kilometers
projection corrections should be minimal.  What is the best way to load
this map - tile cache with a single tile ? What is a good projection to
use ?
