[OpenLayers-Users] Using Aerial photos
Jachym Cepicky jachym.cepicky at gmail.com
Tue Feb 19 01:52:38 EST 2008
MilesTogoe píše v Po 18. 02. 2008 v 17:19 -0700:
> I want to use an aerial photo as the base map - I have lat/long
> coordinates for the map corners.  What is the best way to use this if I
> don't know the projection (since it is only 10 square kilometers
> projection corrections should be minimal.  What is the best way to load
> this map - tile cache with a single tile ? What is a good projection to
> use ?
afaik, if you have corner coordinates of the photo, they have to be in
some projection already. If the are in lon/lat, you can use openlayers
default projection epsg:4326 (WGS84).
I would use single file, for the image display. it is imho the easiest
way, how to put some data on the screen.
jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
	=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
	=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080219/472ca57e/attachment.bin
