[OpenLayers-Users] Detecting a click in a feature
Eric Lemoine
eric.c2c at gmail.com
Fri Feb 22 11:19:20 EST 2008
On Fri, Feb 22, 2008 at 2:07 PM, Carlos Pinto <cmspinto at gmail.com> wrote:
> Hi all,
> I was using google maps and last week I decided to use OpenLayers, so I'm
> quite a new user.
> So now I'm changing all my code to OpenLayers, but I have this problem that
> I was adding features from a database and then I was showing the balloons
> with the description.
> Now I want to show it in a table that it is outside the map. But can anybody
> advise me what is the best way to add features from the database (they can
> be hundreds of polygons),
You can possibly use MapServer as a WFS server and use
OpenLayers.Layer.WFS. For that, your data needs to be in database
MapServer can read from (e.g. Postgresql/Postgis).
> I have try to use GML and the text file, but once
> they are in the map I can not detect when a feature was clicked, I was using
> this code:
> function init(){
> var mylayer = new OpenLayers.Layer.GML("GML",
> "../KML/MyPolygon.xml");
> map.addLayer(mylayer);
> selectControl = new OpenLayers.Control.SelectFeature(mylayer,
> {onSelect: onFeatureSelect, onUnselect:
> onFeatureUnselect});
> selectControl.activate();
> But doens't work, does anybody knows why?
Your code looks perfectly correct to me. What OL version are you using?
Eric
