[OpenLayers-Users] Layer rendering
Carlos Pinto
cmspinto at gmail.com
Tue Feb 26 10:13:10 EST 2008
Hi all,
Can anyone explain why when I run the example:
http://www.openlayers.org/dev/examples/kml-layer.html
it appears a line and 3 polygons with 3 different colors and if I use
exactly the same code with the same layer, the polygons are replaced by one
line?????
The code is this:
map.addLayer(new OpenLayers.Layer.GML("KML", "kml/lines.kml",
format: OpenLayers.Format.KML,
formatOptions: {
extractStyles: true,
extractAttributes: true
and in fact, the layer has three polygons with different colors. What am I
missing.
I have try also to reference the library that it is online but i still stay
with out seeing the polygons.
Can anyone explain this?
Thanks
Carlos
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080226/ca4a82ed/attachment.html
